changing mbox to digi002r for a session
will all the i/o settings appear when i connect the rack? or do i have to add them? or will it be best reinstalling 6.9 with the rack attached? will this auto detect the i/o's?
cheers |
Re: changing mbox to digi002r for a session
anyone?
My best bet is that you need to re-install. If only to get the drivers for the 002r installed. No biggie IMHO.
What's that? - That's the machine that goes "pling". Bastiaan |
Just plu in the 002 and open protools. It should recognize the hardware but you still need to set up your I/O anyway.
so i go into my i/o setups what will i need to do? i notice there is an mbox thing there now. what will i need to do to setup the i/o's? i know i will have 1-8 straight in to the rack then 9-16 via adat lightpipe. so what will i need to do?
If you are installing the 002 on the same computer, you may have to install a driver, maybe nopt, but I use my mbox at home and the 002 at the studio and there is no problem switching between them (different computers though). If you used the 002 to record and have inputs slected that the mbox doesn't have, it just makes htem inactive until you go back to the 002 (if you ever do), then when you go back to 002 they are active again. If you need to change the inout for whatever reaosn, PT knows which interface is connected and will give the appropriate options. Same goes for outputs. A quick way to change inputs, if you don't already know this, is to select the tracks you need to change, then hod shift-alt and select the input, this selects the same input, output, aux send, etc for all of the selected tracks. control-shift-alt slects them in increments for all selected (say you sleetc 8 tracks wanting to assign adat 1-8 to those tracks respectively- select the 8, hold control-shift-alt, click on the forst tracks input, select adat 1, and voila!, each track has the next available input, so 1 would have adat 1, 2 would have adat 2, etc.). Even easier in 6.9 now that you can shift click to select a rnage of tracks. Hope that helps.
thats excellent. thanks
Input levels changing on Digi002r | bennylesticks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-30-2012 03:42 AM |
Track levels in session keep changing when the session is re-opened. | Pred80r | Pro Tools TDM Systems (Mac) | 3 | 11-14-2009 01:31 AM |
Rename session - changing session name | majdi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-18-2008 12:20 PM |
Digi002R vs MBOX | Ralph K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-06-2004 12:33 PM |
digi002r looses firewire connection during session | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-23-2004 07:51 PM |
