Old 04-29-2013, 11:57 AM
FreeBlues FreeBlues is offline
Default Output to Mains On?off?
******Never mind, I figured it out***
This is driving me crazy! I am trying to hook my 11R to a PA, simple, basic, easy. Wrong. When I connect an XLR cable from either the left or right Main output on the 11R to an input on my mixer, there is no sound, no signal. However, when I use either of the Guitar Outputs on the 11R (using a standard 1/4" cable) to the mixer, everything works perfectly.
I've read through the manuals and there isn't any mention that I need to route the output to the mains, turn them "on", but I'm wondering what simple thing I am overlooking.
I can use the guitar outputs I suppose, but not all mixers accept a 1/4" cable input. I can always just get a 1/4" to XLR cable, but this seems wrong.
Any obvious reason I can't get an output signal when connecting the Main Outputs?
Old 04-29-2013, 02:42 PM
ThunderKyss ThunderKyss is offline
Default Re: Output to Mains On?off?
So....... what was the deal?
I don't think you should have to do anything special. I took XLR cable to TRS & plugged straight into my mixer & it works... I have no idea if the amp outputs work, haven't had the need to try yet.
MacMini OS x 10.14.6
Core i5 2.5 GHz 16GB
Eleven Rack
Old 05-01-2013, 12:09 PM
Not especially intuitive. Hold the Edit button and go to User Options. Scroll to 'Volume Control'
There are selections for 'Main Mute' and 'Phones Mute'.
Great options, just not real easy to find and the manual says nothing.
Old 05-01-2013, 12:50 PM
Benoni's Avatar
Benoni Benoni is offline
It actually is in the user guide, page 90 of the PDF, or just search "mute" in the PDF.
You can also mute/unmute these option with the on-screen editor.
One thing to note is that if an output is muted when you turn the rack OFF, when you turn it back ON, it may look like the output is not muted (button is not lit) so if you are not getting output, the first thing to try is cycle the mute buttons.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-02-2013, 04:51 AM
zedhed's Avatar
zedhed zedhed is offline
Lol...RTFM!
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
C/M on mains fader vikingthor VENUE Live Sound Systems 5 10-08-2011 01:35 PM
Eq Sc 48 mains YellowDissident VENUE Live Sound Systems 2 05-21-2011 06:57 PM
Monitor mains on 002 c1jv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2006 09:45 AM
CPU noise through AC mains skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-26-2004 06:35 AM
Mains Hum phamtec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-23-2001 12:58 AM
