PT LE fails to launch
I have an MBox2 with Protools LE and the Factory plug-ins running on Windows XP; the programme recently failed to launch (I think it hung on 'creating DAE objects'). Anyway, I decided to re-install everything Protools-related, including my Factory plug-ins. The launch now freezes when it tries to install the first Factory plug-in. (The iLock key is in.) If, however, I uninstall the Factory plug-ins (using the Windows 'Add/Remove Programmes' utility), Protools launches o.k. (though obviously without the plug-ins).
Any advice would be gratefully accepted as I use Maxim a lot. |
Re: PT LE fails to launch
What OS and Platform are you on?
I know on Macs, if you installed the melodyne plugs first, or the reason adapted plugs first you may have issues with it crashing when it sees the component part of the plugs. I had to remove the components from the library>audio>plugins>components folder in order to get LE8 to start right the first time, and I think I had to clear out a cache file too, (maybe that was in logic) but after doing so, it was cool, started up, and I was able to reinstall the melodyne and rewire plugs and everythings cool now. Another thing could be the OS may not be current enough, you might not be meeting the hardware compatibility requirements, or two or more apps could be competing for core-audio's attention (if on a mac) |
Hi there,
I'm on a PC running Windows XP SP3 and Protools has worked fine with the plugins until recently. As I work mainly in radio, I have no need for the Ignition Pack plugins, such as Melodyne and Reason so those are not installed. The same copy of Protools works fine when the MBox2 and iLock key are transferred to my other desktop and also my laptop. I did recently remove quite a few items from the computer's startup menu in order to speed things up (maybe I removed one thing too many!) Also, I added an external USB backup drive. I might try re-tracing my steps to see if any of these has caused the problem. Thanks for your time. |
Didn't by chance just install Internet Explorer 8, did you?
Yes I did - are there known issues with IE8? If so, I'll try reverting to IE7.
Thanks a lot. |
Hi there - I've now uninstalled Internet Explorer 8 and everything is back to normal! Thanks very much for your suggestion.
I've had the same issues but reinstalling IE7 has still stuffed my system.
Does cs9 patch for PT address any of the IE8 issues at all?? |
No, Digi recommends NOT installing IE8 AT ALL. Check this out..... http://duc.digidesign.com/showthread.php?t=243183 With other viable browsers that don't screw things up (like Firefox), it's best to avoid IE8 completely. |
Pro Tools fails to launch | alin | Windows | 7 | 06-29-2013 05:48 AM |
PT 7.4.2pr Fails to Launch | pk1983 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-16-2008 04:58 AM |
Pro tools 7.1.1 fails to launch | myles hallett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-06-2008 05:46 PM |
LE 7.0 fails to launch (-48) error? | rinky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2006 09:07 AM |
fails to launch | ninslayer2000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-15-2005 07:35 AM |
