Old 06-05-2010, 02:12 AM
richeymcc richeymcc is offline
Default Re: Lost Communication with Audio Interface!
Originally Posted by Dism View Post
Have you tried a fresh re-install of PT yet? Seems like the best option at this point.
Do a full and complete uninstall with the uninstaller. Use the FULL 8.0.3 installer. It should be available for download on your Avid account page.
I'll do that-thanks,
There's an option for the safe uninstall or the complete one-the safe one is recommended-which would be the better option?
Macbook Pro - 2.33GhzIntel Core 2 Duo/2Gb RAM 677Mhz -
OSX 10.5.8
Protools 8.0.3cs2 LE Digi 003+Rack.
G-DriveQ 500Gb ext. hard drive 7200rpm- eSata- Partitioned
Old 06-05-2010, 02:20 AM
Dism Dism is offline
The complete uninstall. Everything gone, except your plugins folder.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-05-2010, 11:17 AM
Just did the complete uninstall and then re loaded the whole program. From the start-"lost communication with interface...." and then it just quit the program!
I think it's something to do with the Reason Rewire..some other sessions without Reason as a rewire will work fine.
Thanks for all your help by the way!
OSX 10.5.8
Old 06-05-2010, 11:42 AM
So this only happens with particular sessions? Does it ONLY happen with ReWire sessions?
You have tried updating Reason already, yes?
If this is the case, my advice is to create a blank session, and turn on Reason in the session. If it crashes... then we can officially say Reason/Rewire are involved. Otherwise, you might just have a corrupt session or two. In which case, Import Session Data should help you.
D
Old 06-07-2010, 11:33 AM
Haven't updated Reason,
but tried a blank session without reason as a rewire and it still comes up with "lost communication with interface" message, as soon as ProTools loads up! Could this be a faulty firewire lead? One thing i haven't checked so far..
I tried import session data to a fresh session but error came up about not being able to use the source disk and to check disk allocations, which i did, but couldn't see what the problem was.
OSX 10.5.8
Old 06-11-2010, 10:47 AM
I have since transfered all audio to a new session and it runs fine, though very slow. The "lost communication" error stopped showing. But as i was mixing, anytime i tried to add the ElevenFree plugin it crashed and kicked me out! I ended up using a Sansamp plug instead which ran fine, but as i said, slowed down the session considerably!
Maybe it was a combination of Reason/ElevenFree plugins and having a corrupt session?
Thanks for all the help-hope this will help someone else who may have similar problems.
Rich
OSX 10.5.8
Lost Communication With Audio Interface -6097 Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-20-2012 08:07 PM
Lost Communication With Audio Interface -6097 Bren10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-17-2010 04:42 AM
Lost Communication With Audio Interface classickstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2010 12:30 AM
003 - lost communication with audio interface -PT LE 8.1 alex s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 12-01-2009 12:48 PM
Lost communication w/the audio interface (-6097) Meko511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-31-2007 01:39 PM
