pt10hd trial
i'm running pt8 HD on mac osx 10.6.7
if i install the pt10hd trial (ilok required) can i run it alongside my current software on the same drive with the same ilok without worry of interference of any kind? |
Re: pt10hd trial
No you can't run PT10 along side PT8. PT 10 will overwrite 8. Best option would be to clone your current system drive and use that to test PT 10. If you do install over PT 8 and don't decide to upgrade and continue with PT 10. Then you'll need to save all your songs that you did on 10 as PT 7-9 format so you can open them in 8 again. Yes PT10 can use any interface with a core audio driver. Chris
Pt 8 hdn -> pt10hd | brucecoughlin | Pro Tools HDX & HD Native Systems (Mac) | 1 | 03-15-2012 06:27 AM |
PT10HD Trial and Trial Licence Not seeing! Urgent!! Have session in 2 Hours!!! | mozart | macOS | 6 | 12-29-2011 08:05 PM |
AVID - If PT10HD 30 day trial expires and HDX system has not shipped... | ronwasserman | Pro Tools 10 | 6 | 12-15-2011 07:32 AM |
Have PT9 but want to try PT10HD trial | dccarson | Pro Tools 10 | 1 | 12-08-2011 11:37 AM |
PT10HD and S/L or Lion? | danander11 | macOS | 4 | 11-01-2011 09:16 AM |
