Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-24-2014, 03:01 PM
Cartoonguy Cartoonguy is offline
Default Sync issue using Mbox 3
I am using some professional animation software (TVPaint) and I came to notice that when I use the Mbox 3 for sound output instead of my iMac's built in sound, the sound plays about half a second late, which is terrible. When I switch back to the internal sound, it plays perfectly in sync. Thing is, this only happens with TVPaint, but given that it plays perfectly when using the iMac's built in sound, the software support would tell me it's to do with the Mbox and not them. I wonder if anyone has any idea why the Mbox 3 would cause this major issue with this one application. It means I have to switch outputs when using it.
Old 09-26-2014, 04:36 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Sync issue using Mbox 3
If it's a TV program, I assume it's running at 48kHz. Have you changed the sampling rate of the MBox?
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 09-26-2014, 04:48 PM
It's called TVPaint, but really it's an animation program, like say, Flash. The audio is based on the audio file I import, so in this case the .wav file is 48kHz and the Mbox is indeed set at 48k as well. Any other setting you can think of that might impact on this?
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
spdif mbox - orpheus sync drop out issue mafiacondon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-27-2010 11:24 AM
MBox digital sync support issue?....Hugh? pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-07-2007 08:56 PM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
Can Mbox sync to midi timecode or smpte sync? greeneye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2004 08:47 AM
