Computer gets REALLY slow after awhile...
hi guys!
I got a problem with my Pro Tools LE 8.04 setup. After a while the computer gets really slow. and often hangs. anyone know why? Thank you My sandra report: SiSoftware Sandra Computer Workgroup : WORKGROUP Host Name : Oscar-Dator User : Oscar Processor Model : AMD Phenom(tm) II X4 945 Processor Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Gigabyte M57SLI-S4 BIOS : Award (Phoenix) FHL 11/06/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR2 Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 8GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 402MHz (804MHz) Memory Module(s) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : A-Data 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Video Adapter : ATI Radeon HD 3850 (320 SM4.1 669MHz, 512MB DDR3 2x700MHz, PCIe 2.00 x16) Graphics Processor Storage Devices Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (D:) Hitachi HDS722580VLAT20 (82.3GB, ATA100, 3.5", 7200rpm, 2MB Cache) : 77GB (E:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 149GB (F:) SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (G:) WD 5000AAV External 500.1GB (USB) : 466GB (I:) TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:) AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (K:) Logical Storage Devices Hard Disk (D:) : 75GB (NTFS) @ Seagate ST3802110A (80GB, ATA100, 3.5", 2MB Cache) Arkiv (E:) : 77GB (NTFS) @ Hitachi HDS722580VLAT20 (82.3GB, ATA100, 3.5", 7200rpm, 2MB Cache) Reserverad av systemet : 100MB (NTFS) Hard Disk (F:) : 149GB (NTFS) @ Hitachi HDS721616PLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) Hard Disk (G:) : 699GB (NTFS) @ SAMSUNG HD753LJ (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) My Book (I:) : 466GB (FAT32) @ WD 5000AAV External 500.1GB (USB) Hard Disk (C:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Optical Drive (H:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (K:) : N/A @ AJSHSTO S1QF4D2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Giga-Byte MCP55 LPC Bridge LPC Legacy Controller 1 : ITE IT8716F Audio Device : Giga-Byte MCP55 High Definition Audio Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Device : Giga-Byte Radeon HD 3870 Audio device Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte MCP55 IDE Disk Controller : Giga-Byte MCP55 SATA Controller Disk Controller : Giga-Byte MCP55 SATA Controller Disk Controller : Giga-Byte MCP55 SATA Controller USB Controller 1 : Giga-Byte MCP55 USB Controller USB Controller 2 : Giga-Byte MCP55 USB Controller FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Computer gets REALLY slow after awhile...
Some things to try:
Keep that USB drive disconnected except when you are backing up to it(recording to USB drives is no supported and anything on the USB bus could affect the bus speed, important for Mbox users). Make sure you have done all the system tweaks(including disabling power management on all USB ports). Disable network. Check you system temps(google search for monitoring utilities) as heat could be causing something to degrade. How old are your hard drives?(could be a sign of impending drive failure). How full is your recording drive(try to always leave 15-20% free space minimum). Why this setting in BIOS???......Multi-Processor (MP) Support : No
Pure Class.
My system temps are normal (Used speedfan). How do i change the BIOS settings? Of course i want multiprocessor support! Again, a big THANK YOU for your help! |
For BIOS settings, read the booklet that came with it(every mobo seems to have its own idea on that). Disable network(at least until you are positive it is NOT part of the problem) by going into Device Manager and right-clicking on the network card(s) and selecting Disable. Disconnect anything you don't NEED for Pro Tools until you figure out what is dragging your rig down(the less things attached, the less possible problems). You may want to update your BIOS version(mine started at F2, but going to F4 made a large improvement). Also, my Gigabyte mobo worked poorly with the RAM timings set to AUTO. Setting them to manual and setting the timings according to my RAM made a night and day difference. Since you have a very different system, YMMV(again, consult the mobo booklet for how to set RAM timings and get the correct timings for your exact RAM).
Can't find how to set the RAM timings either... Probably alot of stupid questions, but i've read the manual, searched on google etc and i still can't figure it out. Please help Thank you |
Sadly, I am not skilled enough to help further. Maybe you can find a local PC guru to help?
all right, thank you anyway. I can't afford a computer guru haha. do you possibly know anyone here at the DUC that might help?
Thank you |
A little update.
Asked a guy who owns a computer store about Multiprocessors. He said that my computer don't support multiprocessors, it only have one proccesor, but with 4 cores. Does that help anything?? |
A good place to start is to start up Task Manager ( Type: Ctrl/Alt/Delete at the same time).
Click on the Processes tab. Note everything that is running and how much memory they are using, and how much CPU they are using. Keep Task Manager open, then open ProTools and start working a project. Check in on Task Manager every once in a while to see what is changing. Eventually, you will see a process that is either taking up a lot of cpu or memory. That is your culprit. Generally, the behavior you describe is called a "Memory Leak", which basically is a application starts using up a lot of RAM but won't release it back to the OS to use after it should be done with it. If ProTools winds up being the offender, then most likely you have a plugin/softsynth that is the culprit, most likely that they have a denormalization issue. It appears putting a dither plugin before that plugin will solve the problem. Again, this is just a place to start, but will usually produce something for you to check out. |
Protools runs so slow on my computer! Please help. | nfm420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-31-2006 09:29 PM |
My computer is too slow!!! | funmusical | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-06-2005 10:43 AM |
Slow Computer Start-up | Mixodigian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-18-2004 08:03 PM |
Slow computer? 1.8 ghz, 512 ram, still slow | musbkc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-29-2003 06:53 AM |
OS9 makes my computer start up really SLOW!! | Thumb | Pro Tools TDM Systems (Mac) | 7 | 03-22-2000 11:33 AM |
