  #21
Old 04-09-2018, 05:48 PM
JTee JTee is offline
Default Re: Feedback loop
Hi guys,
Sorry for the delayed response, I tried changing the routing in a very basic project (just 1 track with XPand!2 loaded), but still getting the same noise issue, and there is a high latency when I play a note on my midi keyboard
see attached for the routing
Intel Core i5-4590 3.30 GHz
8 GB RAM
Windows 8.1
Pro Tools First 2018.3 Windows
Sound module: Roland Duo-Capture Ex
Midi controller: Roland A-49
Video/Graphics: NVIDIA GeForce GT 635
Storage Devices
WDC WD10EZEX-60M2NA0 1TB
  #22
Old 04-10-2018, 04:41 AM
Originally Posted by JTee View Post
Hi guys,
Those input and output names don't look correct. On the output field for instance what is the main output of your audio interface called in I/O setup? And you don't need an input on an instrument track. And as far as latency what do you have your buffers setting at? There's also a small amount of MIDI latency.
Jack
QAPLA!
  #23
Old 04-10-2018, 02:58 PM
Ok, thanks.
How do I access the I/O setup?
The only option I see for Output is what shows in the screenshot in my previous post.
As for buffer settings, see attached screenshot, I've tried adjusting these settings already, but it doesn't help
Also, noticed for MIDI Input settings, it uses the word "emulated", not sure if that might be part of the issue?
8 GB RAM
Windows 8.1
Storage Devices
  #24
Old 04-11-2018, 04:16 AM
Ok, thanks.
I'm talking about the I/O setup in PT. Take a look at the manual aka the user's guide.
Jack
QAPLA!
  #25
Old 04-13-2018, 05:49 AM
ok, thanks for the suggestion.
Unfortunately there is no "I/O" option in the Setup menu for Pro Tools First.
Not sure what else I can try?
Thanks again for all the previous suggestions though
8 GB RAM
Windows 8.1
Storage Devices
  #26
Old 04-13-2018, 08:11 AM
That's weird; wish I could help more but that bit of news stumps me.
Jack
QAPLA!
  #27
Old 04-16-2018, 07:15 AM
ok, thanks very much for your help
Does anyone else have any suggestions?
Please help
8 GB RAM
Windows 8.1
Storage Devices
  #28
Old 04-16-2018, 02:50 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Disable MIDI for duocapture interface. That is only for midi controllers/receivers. This should fix your issue but also uninstall/reinstall Duo capture driver if necessary after disable midi on duocapture PT first does not have setup menu so if the driver is working right you should be ok
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Feedback Loop Lilmac56 General Discussion 4 12-22-2017 06:03 PM
Feedback Loop jamuprod Pro Tools HDX & HD Native Systems (Mac) 1 07-09-2013 02:16 PM
Feedback loop PunkRockTom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2011 11:33 AM
Help-feedback loop! sid5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-19-2006 11:42 AM
002 and 5.3.2 feedback loop Zeek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-15-2003 10:32 AM
