Old 04-21-2002, 02:28 PM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default Nights @ the Sound Table.... I just can\'t stand it...
... went trough the numerous posts about mastering and just read what I already knew: C4 & L1 (or L2)
should do the trick... And then some more tricks: use a HP roll-off @ 40 Hz, apply some BF-plug after the C4....
AND STILL MY REFERENCE STUFF IS TWICE AS LOUD [img]images/icons/confused.gif[/img]
Of course I know there's something called a Finalizer and sw like T-Racks and UV22... still I don't get it...
If I push the envelopes more, it will distort and on PAZ everything looks nice and swell, no abnormalities....
What am I missing here ? Is there a way to press louder on CD ... Is there ?
The stuff I'm mastering now is underground hip hop, so volume IS an issue...
looking for the golden tip [img]images/icons/smile.gif[/img]
Arno Peeters
Tape TV Productions
Old 04-21-2002, 03:32 PM
BboY BboY is offline
Default Re: Nights @ the Sound Table.... I just can\'t stand it...
Hey Pete try this:
Bounce your mix to a stereo file using L1 not L1+ to get the volume up to 0db then import this file into a seperate session and use these plugins
1----RenComp with very little--1.25 ratio and subtle threshold--3 to 3.4--This plug to just level and add Warmth to tracks...Lower the gain for no more than .3 (under the gain faders)
2----C4, with Electro Mastering preset selected--turn the 2 high bands Gain down from preset 2.4 to 0 or even lower for even more warmth and great sound...
3----S1 with 1.6 shuffling and 1.2 trim for wonderful stereo image... and...
4----L1+ with no more than 5 to 6 db of attenuation after entire song has played and 40 on release...if you want more dynamics and less volume restrict the attenuation even more
Now between 3 and 4 i use my reneq to roll off low end 40hz and below and touch it up a bit and then i add the L1 on step 5
This should get you mixes up there [img]images/icons/grin.gif[/img]
P.S I got this setup from Guitaies sorry for the mispelling [img]images/icons/smile.gif[/img]
C-Ya BboY :)
Old 04-21-2002, 04:05 PM
Jules Jules is offline
Best tips
Are you listening to your refs;
via the SAME converters?
Clocked by the same WC?
Only when you fix that up can you be doing real A/B ing..
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 04-21-2002, 04:48 PM
audiaudio audiaudio is offline
Originally posted by Arno Peeters:
AND STILL MY REFERENCE STUFF IS TWICE AS LOUD. . . . What am I missing here ? Is there a way to press louder on CD. The stuff I'm mastering now is underground hip hop, so volume IS an issue...
<font size="2" face="Verdana, Arial">Arno,
Loudness and volume are different animals.
Your mix can be the same volume as another mix and still not be as loud.
Judging from the amount of compression you're using, I'll guess that your mixes are already the same volume as your reference stuff--but not as loud.
Matching a mix's loudness to a reference is not as simple as using a particular piece of equipment or a PT plug-in. You have to mix in a way that fills the frequency spectrum in the same way that your reference fills the spectrum.
Do this: After carefully matching the playback levels of your mix and the reference, compare the elements of your mix to the elements of the reference. For example, compare your kick to the reference kick, your bass to the reference bass, your vocal to the reference vocal, etc, and try to make those individual sounds similar. Once those elements begin to correspond to your reference, the loudness of your mix will also start to match up.
It's a journey! Hope this helps.
 HD Accel 2 | PT 10 | Mac Pro | 5G RAM | OS 10.7 | MBP Retina | 002R
Old 04-21-2002, 11:51 PM
B-Boy, thanx 4 da tips !
Jules: good point, yes; I imported 'em in PT
Audiaudio: yes, very true (volume vs. loudness).
I was thinking of that too: some of the stuff is loop-based with just 3 or 4 sample inredients added.
So 'empty' as in 'not the full spectrum' applies.
But on the other hand: it's not just one, but all 17 tracks that suffer from a lack of punch.
The reference material is very close to what I'm doing in terms of style, budget etc.
I was wondering: I used to not worry too much about reds in the sub,-and masterchannels, as long as it sounded ok.
This time, I reduced gains until no overs were left.
(Thought I do it the proper way this time....)..
Maybe that could play up ?
Btw.: I mixed down from the original session to a 4 ch session for mastering (instrumental + vocals) with nothing on the master fader except IDR. All is done @ 24 bits / 44.1 kHz
Arno Peeters
Tape TV Productions
Old 04-22-2002, 01:27 AM
Mullholland Mullholland is offline
arno, maybe your refernce material was not created on PT. [img]images/icons/grin.gif[/img]
Old 04-22-2002, 02:15 AM
<font size="2" face="Verdana, Arial">Lots of rock, R&B, and rap CDs contain many flattened overs.
Take a look at the waveforms of Rodney Jerkins' stuff (Brandy, Destiny's Child, Michael Jackson), and you'll find levels that are beyond hot.
Obviously, for Rodney and others, what you see on the meters doesn't really matter--it matters only how it sounds.
Old 04-22-2002, 10:33 AM
Ok, but just run some stuff trough a L1 and it will look just te same, without any red led at all....
I mean over in the sperate channels of the source session...
Arno Peeters
Tape TV Productions
Where can we watch last nights webinar 50-55 minute video Southsidemusic Pro Tools 11 2 04-09-2013 04:08 PM
Is last nights webcast available for re-streaming? Craig F Pro Tools 10 3 10-21-2011 04:35 PM
Chipset Table?? unsufferable Pro Tools TDM Systems (Win) 1 02-12-2010 08:27 PM
Mbox for stand alone sound card Greg555 Tips & Tricks 3 09-24-2008 05:05 AM
$60,000.00 On the table?!?!?!? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-27-2002 07:30 AM
