Old 03-28-2018, 06:28 AM
Sir Hannes Sir Hannes is offline
Default set automation to off/touch (shortcut)
I am asking for a shortcut. In the Control app there's an EUCON "Automation -> Modes -> off" / "touch" macro - but this is not working here.
Old 03-28-2018, 09:03 AM
Default Re: set automation to off/touch (shortcut)
Given this question and your other post, I suggest you describe your entire setup and system so maybe somebody can offer better advice
Old 03-28-2018, 10:43 AM
oh, realized I put the specs into my profile, not in the signature.
MBP Late 2013 OSX Sierra
ProTools 12.5
EuControl 3.7
LogicPro9
Old 03-28-2018, 02:09 PM
What's the Eucon running? More details please
Old 03-28-2018, 02:18 PM
BScout BScout is offline
My mistake that I was corrected on how it works from the app:
You need to hit "do to all" or "do to sel" before pressing the automation mode.
Old 03-29-2018, 02:02 AM
oooooh I looooove you soooooo Thank you!!!
Just for my knowledge: I searched in the reference guide, the controlapp PDF, and the shortcuts guide for "do to" "do to all". Only in the reference guide under HEAT Avid writes about this command. For what more is it useful?
ProTools 12.5
EuControl 3.7
LogicPro9
Old 03-29-2018, 03:06 PM
You use it the same way of option (do to all) or shift+option (do to selected) from the keyboard. So, for instance, if you want to put a bunch of selected tracks into record from the App, select the tracks, hit "do to sel", then click record on one of the tracks.
It's the workaround for the fact you can't press two macros at the same time on the App to get this kind of function.
Only the automation modes require it for even one track selected. Which is where you (and I) got stuck.
Old 03-30-2018, 05:08 AM
I appreciate your help! Happy eastern to you and the whole community here.
ProTools 12.5
EuControl 3.7
LogicPro9
Old 03-31-2018, 10:18 AM
I continue on this task about "do to selected":
menu -> edit -> delete PAN automation = works without going into the PAN lane.
now: copy PAN automation -> PASTE to current automation type = is only working, when I see the PAN lane?
ProTools 12.5
EuControl 3.7
LogicPro9
Old 03-31-2018, 10:36 AM
I bolded the important point.
Pro Tools doesn't know what the current automation type is unless, well, the lane is visible. That's what tells it "the current automation type"
If you want to just paste (not "paste to current automation type") you can do that and it will paste to the same Pan lane without having the pan lane visible.
How to read/touch Automation while recording? Rockman413 Pro Tools 10 7 05-13-2012 09:29 PM
Bad behavior of Touch automation Mode bortraws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-01-2008 04:38 AM
Automation overwrites data even if you do not touch anything Ale Pro Tools TDM Systems (Mac) 4 05-27-2007 06:05 PM
plug-in automation an touch-mode jimlongo ProControl, Control|24, Command|8 4 06-22-2005 09:36 PM
C24 Touch Automation Bug autopilot ICON & C|24 0 04-10-2005 08:29 PM
