help (002) - Input Gain ?!
Hey guys ... havent been posted in a while But i'm in need of some help.
I just got my 002 (upgrade from 001) and i'm having troubles with hot mic signals coming in to my 002 clipping ( ie- kick drum , snare drum). The mics are going to my octopre and then to the 002's inputs , but even with my mic pres down all the way the signal is much to hot (way over 0)coming in . With the 001 if I had this problem I would go change in the "hardware" settings and use the software "mixer" to adjust my input gains for said loud channels. Now the problem is where can you do the same adjustments on the 002 !? Is it in PT ? ... Does it have to be done on the 002 unit internally ? Cause I cant find the options anywhere. Any help would be appreciated very much ! Cheers BTW - Running version 5.3.2 (came with 002) .... |
Re: help (002) - Input Gain ?!
There are no pads on the 002.. and there are no line level adjustments for the 002 like for the 001 in the Pro Tools software. If you can't lower the gain to avoid mic preamp clipping, then use external inline pads.
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
Thanks Rail ... I figured it didnt have any Just wanted to hear it from someone incase i was overlooking something simple. I will try to find some inline pads. Thanks for your help
Its quite disapointing/upseting that upgrading to the 002 would be in some ways a DOWN-grade A feature like the 001's input gain "digital mixer" should of been implemented into this device/software combo. I cant beleive the engineers overlooked it. Specialy since its coming from the octopre a DIGI device. But thats a whole other thread. Abywho ... i'll stop ranting thanks again rail |
I always keep a mixer of some kind handy ..sometimes a little mackie and sometimes my DA7 digital console and then would just use the line in inputs or optical inputs of the 001. That way I could trim before it hit the 001.
I don't know the octapre..isn't there a way to trim pad level there and then use line-in into 002?
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24 DELL Dual Core, MBOX/003R PT 8 WIN XP |
And no the Octopre has no trim for its 8 outputs. Unless i'm just a complete idiot and cant see them/know about them. In hine sight I should of purchased the Presonus DIGIMAX (with sweet trims). I have this 002 sitting here and all I'm thinking is how I miss the -26 DB pads from the 001's inputs 1 and 2 ... |
Is their somewhere in protools where you can adjust the input gain for inputs 5-8 in the digi002? Excuse me if you answered this question already.
Rail
That sucks! I was hoping I was looking in the wrong place. Thanks!
Inline mic pads are cheap.
Quad 2.5 G5, 4.5G RAM |
Input Gain Adjusting | kingof6strings | Tips & Tricks | 6 | 02-09-2010 06:42 AM |
Where is "Input Gain" in PTLE 6.1 ? | 3rdstory | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-16-2006 04:09 PM |
PT LE Internal Input Gain? | GrimCoffee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 37 | 07-02-2005 01:52 PM |
INPUT GAIN behind speakers | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2003 04:15 PM |
S/PDIF Input Gain | rfreeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-17-2002 07:34 PM |
