Old 07-31-2020, 08:17 AM
detroitmilty's Avatar
detroitmilty detroitmilty is offline
Default Orchestral Companion not working correctly
Hey all..
I'm new to this community and fairly new to Pro Tools. I purchased the Orchestral Companion plugin from Avid and installed it. When I play it in practice mode, it works fine. As soon as I record enable and try to record on my MIDI track with the rest of the tracks, it just kind of plunks...like I'm plucking a violin string...no sustained notes.
When I switch to the Expand2 plugin, it works fine but I need better sounding instruments, which is why I'm using the Orchestral plugin.
Anybody know what I'm doing wrong?
Old 07-31-2020, 06:43 PM
unkJE's Avatar
unkJE unkJE is online now
Default Re: Orchestral Companion not working correctly
Welcome to the DUC!
I have to engage Loop Record to make it work – whereas taking Loop off worked for others
From this Thread:
http://duc.avid.com/showthread.php?t=389065
“With a selection made on the timeline or in the track everything works just dandy”
“select the MIDI region in Pro Tools so that it's highlighted, it will play back”
“I get the full-length notes for both Normal Record and Loop Record! Initially, it would only work for me in Loop Record”
Please post again if none of the above suggestions work for you ...
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 12-10-2020, 03:01 PM
Interestingly, I took it out of loop and it works fine. Really weird. Thanks so much.
Old 12-10-2020, 03:37 PM
unkJE's Avatar
Originally Posted by detroitmilty View Post
... took it out of loop and it works fine...
Great to read you got it working – thanks for posting – good luck with your music!
SONiVOX Orchestral Companion Strings for US $1 unkJE Virtual Instruments 23 03-02-2017 07:32 AM
midi take not working correctly TeamContra Virtual Instruments 0 10-02-2015 05:29 PM
Solos not working correctly... nortstudio Pro Tools TDM Systems (Mac) 2 07-01-2010 11:18 AM
Maxim not working correctly? brianjanthony Pro Tools TDM Systems (Mac) 7 04-12-2006 05:32 PM
HELP! Zoom is not working correctly! trostals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-20-2002 03:53 PM
