Old 02-27-2013, 02:32 PM
leftalive leftalive is offline
Default MBox Pro 3 CoreAudio Manager says (HW not found), but...
Hey guys and gals, been a while, hope all is well...
I had been running a rock solid 002/Snow Leopard system for years, hence the quiet spell.
Recently upgraded to a Macbook Pro (late 2012) and an MBox Pro 3, and I'm experiencing a weird issue w/ getting the Avid CoreAudio Manager to recognize the MBox.
If I fire up the CoreAudio Manager, it says "unsupported device" and "(HW not found)", BUT - it seems to actually be working just fine.
It shows up as an option in the Sound system preference pane, and system sound comes right through. It also works in Ableton Live. The MBox control panel seems to work fine, and the MBox itself is running fine in PT, afaik, it's just that the CoreAudio Manager won't show as working.
I'd like to get this ironed out, as I can see a scenario in which being able to change the buffer setting in the CoreAudio Manager would be important.
I did have to install and re-install PT and the MBox driver several times before it finally worked. If I remember correctly, installing the MBox driver first ended up being the thing that did the trick to getting it to work for 3rd party sounds.
Has anyone else had this "problem"? Why would it say "(HW not found)" when it obviously is?
MBox driver is 1.1.3, PT is 10.3.3, CoreAudio Manager is 10.3.3, OSX is 10.8.2
thanks in advance
PC workstation:
Windows 10 Pro
i7 6900K
MSI GTX 1080ti Armor
32GB Corsair Vengeance DDR4 3200mhz RAM
Samsung 850 Pro 256GB SSD (system drive)
Samsung 850 Pro 1TB SSD (sample drive)
MyDigitalSSD BPX 480GB M.2 (work drive)
2 HGST Ultrastar 4TB drives (backup)
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 02-28-2013, 12:05 PM
herman_hdz herman_hdz is offline
Default Re: MBox Pro 3 CoreAudio Manager says (HW not found), but...
What cable or adapter, are you using????
regards
Old 02-28-2013, 12:15 PM
Bharath's Avatar
Bharath Bharath is offline
MBox Pro 3 doesnt need Coreaudio Manager.
Coreaudio Manager is used by for 002, 003, HDX, HD and HD Native families.
:: Bharath
Pro Tools Software Team
Old 02-28-2013, 12:40 PM
regards
A firewire 400 to 800. Not sure of the brand, might be the one that came w/ the Mbox Pro.
Huh. Really? So the MBox line are the only interfaces they make that don't use coreaudio for 3rd party apps? I would have thought my endless searching on the DUC and Gearslutz would have turned that up.
Thanks guys. Off to Google I go...
PC workstation:
Windows 10 Pro
i7 6900K
Pro Tools 12.4
A loaf of bread
A stick of butter
Old 02-28-2013, 12:49 PM
No they use core audio for third party apps, they just don't need the Avid core audio driver. This also applies the the Eleven Rack, and I expect/hope all future similar interfaces. You manage core audio for these devices via the standard Apple Audio/MIDI control panel. A much better way to do things. And for more complex things the Mbox Pro 3 come with its own very nice driver control panel.
Old 02-28-2013, 01:05 PM
Ahh, that makes more sense. So the Avid CoreAudio Manager is essentially not relevant when using the MBox Pro 3? I can't hardly find any information connecting the two, when searching here, or GS, or Google, maybe that's why. Most of the threads and posts I'm coming across reference an older MBox, or operating system, or version of PT.
PC workstation:
Windows 10 Pro
i7 6900K
Pro Tools 12.4
A loaf of bread
A stick of butter
Old 02-28-2013, 01:15 PM
Yes, just follow the (very brief) instructions in your Mbox user guide, it says nothing about Avid's Core Audio driver. And the core audio driver notes/download page makes it clear what interfaces it is used for. You should hopefully have found this with a web search.
Darryl
Old 03-23-2013, 03:07 PM
slobrien slobrien is offline
I am having the same problem where coreaudio is not recognizing my new mbox pro. I have clean uninstalled and reinstalled up to 10.3.4 a couple of times.
I am running a2008 imac 24' 2.8ghz with 4gb RAM snow leopard 10.6.8
my mbox pro has package1.1.3 and firmware1.0.3
its working fine in protools 10.3.4 and is correctly recognized and working in my mac's audio midi and sound preferences for itunes safari etc, but the coreaudio program is giving me the unsupported device and HW not found message. No 3rd party applications (garage band and line 6 gear box) are getting any sound from my mbox pro at all. The mbox pro control panel seems to be working fine and shows i am getting signal to it but wont give me any 3rd party software to work
I tried the install of the driver first then protools again and have scoured the avid site trying to figure this out can anyone offer any more help than whats here already?
2:46 pm Update
I did one more clean uninstall of both protools and Mbox pro drivers and i am now getting sound to all of my 3rd party apps although the core audio still has the unsupported device and HW not found message. I have achieved what I needed without the coreaudio!!!!!!! Nice thank you for you advice
Old 03-23-2013, 03:50 PM
Did you read all of this thread? Carefully? The Avid Core Audio utility does not work with the Mbox. Not expected to, should not, it is working as designed not to. So completely irrelevant to any other issues you have. I hope you are not trying to mess with that utility after its explained so clearly above. And of not then your problem is not related to this thread and you should have started a new thread for his problem.
If the Mbox shows up in the OS X Core audio utility then that is a good sign. Are you selecting it as the input device in garage band under preferences>Audio/Midi? Try setting the direct device there, not the system setting and don't mess with aggregate devices. Does that work? If there is much more to this can you start a new thread, start by reading the "Help us Help You - READ THIS Before Posting!" link on this web page, and the type of info asked for there, tryign to be really clean in exactly what your settings are in the audio/midi control panel and in the audio input/ouput settings for any app you are trying to use... we cannot guess what you have set there and that is quite likely the root of this issue, or close to it.
If the driver appears suspect (i suspect this is not the issue), do a "proper"/paranoid driver reinstall: physically disconnect the Mbox, download the latest driver from Avid, run the uninstaller included in the download, reboot the Mac, run the new installer you downloaded. Power off the Mac, connect the Mbox but leave powered off. Power up the mac and once booted turn on the Mbox power.
Darryl
Old 10-29-2013, 10:07 PM
skylark619 skylark619 is offline
What hardware does the Avid Core Audio utility work with? I'm using Logic 9.1.8 with OS 10.7.5 and after backing up and reinstalling Lion to an SSD, I'm unable to use my Digi002 with Logic.
10.2 Update and 003 Avid CoreAudio Manager (HW not found) Oddio Works macOS 7 08-31-2012 06:59 PM
CoreAudio Manager says Mbox 2 Mini Unsupported Final Lap Guy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-16-2009 07:48 PM
10.3.9 MBox Digi CoreAudio Manager / PT LE hangs stefven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-19-2007 07:17 PM
Mbox 2 Pro not seen by "Digi CoreAudio Manager" Curtis Marolt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2007 01:11 PM
Mbox 2 -CoreAudio Manager Unsupported device not c DTM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2006 09:39 PM
