Mixing on a desk and using plugins on desk's sends
Hi!
I sometimes mix on an SSL E desk and want to use a plugin running inside protools, feeding it from a desk's send. But I've found it hard to deal with latency (Hdx system). I saw a deconstructing from Michael Brauer where he uses an Altiverb as reverb, sending audio from an aux at his SSL desk. I guess that latency, in case of a reverb, really doesn't matter that much, as latency can be taken as some sort of pre delay. But, sometimes I want to use a delay or a double, for example, and in those cases latency IS an issue. In the doubler case, it sound like an slap delay! I also so another deconstructing where the engineer sends a vocal to Dimension D plugin from the desk without any distinguishable latency. Which would be the correct, or right way to setup a send from a desk to a plrotools plugin and avoid latency while mixing? TIA |
Re: Mixing on a desk and using plugins on desk's sends
did you try turning off delay comp?
I do mix in an SSL 4K. What I normally do is send from the track within Pro Tools, and not from the console. Console sends go for outboard verbs and delays. Anything in the plugin word I send from inside Pro Tools. This way you don't have the delay problems. There is no way to get things sent from the console to Pro Tools without delays. Like you said,if it's a verb, ok. Anything else go bananas.... Oh, and a lot of people ask me if it sounds different because when you send from within protools the send doesn't get the eq or compressor treatment from the console. It's not a problem for me, if it doesn't sound good, I eq the verb return and voilà!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Are you using HDX-DSP plugins or are you trying to use host based plugins?
There is no much Dsp plugins offering out there... The ones I usually use at least... But that's another story. |
Although the studio has nice outboard delays, I love some of my Echoboy (made over time) presets and some Reaktor XT "crazyness"... |
This is the one thing about UAD plugins that turns me off. I have a Quad card and every plugin reports over 1100 sample of latency. While I CAN use them for mixing in the box, I CANNOT track with them(Apollo solves that, but I don't use Apollo) and working in tandem with an analog console, I think you are just out of luck, unless you can keep the UAD path in the box
But, latency is a PITA anytime you use other than AAX DSP.... |
Why not routing your SSL Master thru an PT Aux track?
OK, if you do automation on the SSL you have to turn off delay compensation otherwise you are too late.
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
Exactly...
WTB ICON D-Control Producer's Desk Producers Desk | evandaum | Buy & Sell | 5 | 09-28-2016 08:14 PM |
Mixing desk compatibility | Carrot Child | General Discussion | 17 | 10-19-2014 10:12 PM |
32 channels out of 002R to mixing desk ? | plexi666 | Tips & Tricks | 2 | 08-15-2005 08:58 AM |
32 channels out of 002R to mixing desk ? | plexi666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-15-2005 06:21 AM |
mixing in PT vs. external desk | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-15-2002 09:12 AM |
