002Rack Inputs out of phase
Here's my story... after getting a Dave Smith Tetra and Mopho to poly chain together I've been frustrated that after using inputs 1-4 on my digi 002 to "mix" them together (there outputs and balances aren't spot on all the time) the sound was vastly different. What I've been doing is having 2 stereo auxes bus to a sub mix of the two synths. I can use the gain knobs on the 002rack to "mix" them and in theory this would work great. However using these inputs I always noticed an odd sound coming from the Mopho, which comes into inputs 1-2. After switching the units around, using the 5-8 inputs as a test, I finally found that one of my 1-2 inputs is out of phase. Sure enough when I bring them in on there own separate mono tracks and invert the phase on one of them everything is right with the world.
Any way this can be fixed? I'm not going to use 2 mono tracks and I'd rather not use my 5-8 inputs as I have other pres coming in those. If the hardware can't be fixed easily is there a way to switch the phase on one channel of a stereo aux track? |
Re: 002Rack Inputs out of phase
Without opening up the 002, you could put a trim plug-in on the track, unlink the left & right (inputs 1&2) and flip the phase of just one of the sides.
it works! thank you |
I know this isn't exactly the right place for this question... but just in case...
Does anyone know how to do this in Ableton Live? |
Are you sure it's phase your hearing and not MIDI latency..?
Just food for thought. |
yeah, there is no midi involved here. Just a mopho's audio going direct to channels 1-2. Also, switching the phase as described above solved it!
Could the audio cable be wired out of phase? As you know, pin 2 is hot, pin 1 ground, pin 3 low.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I tested multiple inputs (same cables) and the rest work fine.
You could make a phase reversing cable by swapping pins two and three.
or buy a phase reversing plug switchcraft comes to mind
or make a permanent fix by opening the unit and soldering the leads correctly |
8.03cs2 Core Audio drive - phase reversed inputs | Vinylizor | Pro Tools TDM Systems (Mac) | 2 | 04-14-2015 08:49 AM |
Inputs 3-8 are 180 deg out of phase with the Stereo 1-2 input on the Hearback | bengineer | Pro Tools TDM Systems (Mac) | 0 | 05-19-2012 06:32 AM |
8.03cs2 Coreaudio driver - phase reversed inputs | Vinylizor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2010 11:54 PM |
002rack inputs 5-8? mixer, pre or ?? | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-25-2004 02:46 PM |
Digi 002Rack and Simultaneous Digiital Inputs | agent_k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-17-2004 07:29 PM |
