3rd Party MIDI Interface/PTLE MIDI Survey
Been thinking of getting a new MIDI interface for
the PTLE rig. What are you guys using that's been relatively trouble free? Also, how's the timing in 5.3 under a heavy load? Haven't seen any of the complaints I used to see about Protools MIDI and I'm getting tired of the clunky Cubase approach. Protools just has a much cleaner and more straight forward approach to everything! |
Re: 3rd Party MIDI Interface/PTLE MIDI Survey
I use a MOTU Parallel port Micro Express, which is a 4 in, 6 out interface. It works pretty darn well, but I'd definitely get the USB version instead of the parallel because the parallel's driver installation can be a PITA.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
I just got a used Motu USB Micro Exp. I like it. Low latency. Easy to use. I did have to pay $20.00 for the manual, because there is no PDF version MOTU will give out because "we expect to get paid for our manuals." Ok, I paid.
Phil, Are you syncing yours with PTLE with a time code? I was just reading about that but haven't figured out what I should do yet. |
midiman 4X4 usb. works great. no hassles.
Are all you guys running 5.3 on XP?
Gracias! |
iam...
Matt
How do you have your midisport hooked up and how did you install it? |
Bump
Midisport 8x8 (serial interface). Works great. lesbrunn
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Midisport 8x8 USB. No problem.
PT 9 and 3rd party midi/audio interface | darkglass | Pro Tools 9 | 3 | 11-19-2010 07:07 AM |
Using 3rd party audio interface w/ PTLE and Mbox ? | moebius_loop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-13-2005 08:17 AM |
Using 3rd party Midi Interface - Emagic MT4 | projectmk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-08-2005 09:00 AM |
3rd party midi interface not compatible on G5? | saifir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-07-2004 10:45 PM |
POLL: Best 3rd-party MIDI Interface? | primafacie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 08-01-2003 12:24 AM |
