  #21
Old 01-26-2015, 05:45 PM
BEN6732 BEN6732 is offline
Default Re: Pitch II does not work properly!
It also has 4000 samples of latency when used as a DSP plugin on an HDX system - rendering it completely unusable for the real-time "screwed-voice" stuff we used to do on our TDM system. And when I use it via AudioSuite it shifts the timing around in seemingly random spots. I hate this "update". It's garbage.
  #22
Old 01-28-2015, 04:36 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Pitch Shift II does not work properly!
Originally Posted by DigiTechSupt View Post
Also, adding it to IdeaScale would be good. [/URL].[/I]
Thank you,
JC
JC, why should anyone take the time to do that since the results are ignored by Avid? How many top 25 IdeaScale desires were included in the new PT12? It's either 1 or zero, depending on what really comes out with 12.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
  #23
Old 01-28-2015, 05:28 PM
YYR123's Avatar
YYR123 YYR123 is offline
I agree, worthless exercise
Daniel
  #24
Old 01-30-2015, 01:28 PM
Brother Junk Brother Junk is offline
Mine has always behaved like that as well but I always use other pitch shift options anyway. The more you shift it, the more artifact-ing you get.
  #25
Old 02-06-2015, 02:21 PM
The Fez The Fez is offline
I had the same problem with protools 11 and the latest Antares autotune. Sounded like crap so gave their license back. Very unfortunate.
  #26
Old 12-26-2015, 06:36 PM
Beardular Beardular is offline
Pro Tools 12 here. Same problem + sometimes it cuts a beginning of a waveform
  #27
Old 07-11-2019, 07:00 PM
Fixius Fixius is offline
I guess this is still a problem, because here I am, wondering why this plugin distorts like crazy when I automate it. Anyone find any fixes, or better alternatives? I can't even rerecord the effect to a new track before it distorts. I don't believe it's an issue of processing power.
  #28
Old 07-11-2019, 07:47 PM
YYR123's Avatar
I still believe this is the truth
Daniel
I can't get my Mic to work properly Djgman925 macOS 8 08-22-2013 01:53 PM
does protools ever work properly? pinnacle macOS 9 10-24-2011 04:37 PM
AudioSuite does not work properly. ali3 Pro Tools M-Powered (Mac) 2 04-15-2009 05:13 PM
882 will not work properly with 888 dwall Pro Tools TDM Systems (Win) 0 08-30-2007 12:20 PM
Command 8 not work properly webby ProControl, Control|24, Command|8 3 07-21-2005 09:41 AM
