Old 01-20-2005, 05:58 AM
Sharritan Sharritan is offline
Default Desperate Need of Help
Last night I setup a new desktop for my 002. I am using a Lacie Firewire drive for all my sessions. When I try and open any session on the new machine I get this message:
"The original disk allocation for this session cannot be used. One or more drives cannot be found or are invalid for this session. As a result, disk allocation has been modified. Would you like to verify the new disk allocation?"
No matter what I say, it doesnt appear to help. After clicking past the error I get this:
"Audio files are on volumes unsuitable for playback. Would you like to copy them to a suitable volume?" The session opens but I have no Waveforms or audio.
No luck there either. The odd part is that I can still open all session fine on my laptop using the same drive. And, I was able to open these sessions on the new machine for an hour or so, then I moved the PC, re-set it up, and now here I am. I have no idea where to go from here.
Please help.......
Old 01-20-2005, 06:20 AM
Chris Cavell Chris Cavell is offline
Default Re: Desperate Need of Help
change it from a playback volume to a record volume in the digibase
Cavell Studios
Old 01-21-2005, 07:14 AM
That was it. Thanks Chris.
One more question now.... Now that I have gotten into the sessions, I have one that says it cant find 2 of the audio files. Unfortunaltly, they are on of the main vocal tracks as well as guitar. I tried searching for them myself, with no luck. Is this a normal thing to happen?
ALso, is it normal to have to check disk allocation each time I plug my external drive into a different system? I have had to do it for every session until I save the session again.
Thanks for all your help.
Old 01-21-2005, 08:11 AM
Do they show up when the drive is connected to the original system? They may not be on the external drive. Try performing a "save session copy in" including all files prior to moving the session.
Yes.
Cavell Studios
Desperate luoneill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-05-2010 10:46 AM
desperate for help shaela Post - Surround - Video 1 04-12-2007 09:53 PM
NEED DESPERATE HELP PLEASE!!! thumbolt68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2006 09:18 PM
Desperate to know standish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-25-2005 07:11 AM
I am now desperate! Please DUC - come through for me!!! winter20 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 11-30-2002 06:52 PM
