Mixing multiple vocal tracks
When mixing say a four part harmony.... how do you go about EQ choices? Do backing vocals usually have a good majority of the lows taken out? How would you go about EQing and panning a four vocal harmony? Any Suggestions? |
Re: Mixing multiple vocal tracks
Is one of the vocal tracks a lead vocal? If so, leave it where it is, and pan softly around them with the other 3 tracks.
If none are "lead", then I'd pan two +/- 10, and two +/- 25 just for starters. I wouldn't go too wide if it's supposed to sound like a group singing. If a vocal is singing something different lyrically, pan it off wider. Remember REM's "The End of the World", where the "I, I, have some time alone" comes in over the top of the chorus? That's panned wide, if memory serves. For an even more experimental approach, heck, put on some headphones and just listen to some Queen. Yes, I usually cut off more lows on backup vocals, but it totally depends on the voices and registers. In order to keep backup vocals from crowding the lead vocal, I'll give them a bit more reverb, delay, whatever. In general, cut off as many lows as you can without seriously changing the sound, and boost the high end a smidge for some air. Maybe boost the lower midrange (around 200) of the lead vocal to give it some strength. Also, roll off the high end on your reverbs, delays, etc. to get rid of shrillness.
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
I usually just add highs to bvs. Rarely will i cut the lows much if at all. Also, for the verbs, i usually cut highs and lows of the verb. This keeps it from getting shrill up top and from muddying your mix down low....
Chris Beaver Music www.myspace.com/chrisfrankmusic The Note Music www.myspace.com/thenotemusic Dual 2.0Ghz PPC 3gb Ram, Digi 002R |
mixing multiple tracks to a single stereo track | billardis | Windows | 2 | 10-12-2013 04:36 PM |
Recording multiple midi drum channels to multiple audio tracks? | ewan.mcghee | MIDI | 7 | 07-18-2011 01:46 PM |
Vocal Mixing Help | laozi | Tips & Tricks | 8 | 01-15-2008 06:48 PM |
Vocal Mixing Help... | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-01-2005 01:36 AM |
Any advise on Compressing Vocal tracks during mixing | Dead River Studio | Tips & Tricks | 21 | 01-31-2003 11:06 AM |
