Old 11-18-2013, 09:02 AM
Touchwood Studios Touchwood Studios is offline
Default Is Dynamic Plug-in Processing messing up some VI's
I have had issues with Strike a Superior playing out of sync ( at times ) with Dynamic Plugin processing enabled. I have had the sync issue for a while now I think i have traced to this feature. Is anyone else having this problem?
I have seen other posts with this problem described but they were thinking is was ADC bug in PT 11.
Old 11-19-2013, 10:31 AM
Bharath's Avatar
Bharath Bharath is offline
Default Re: Is Dynamic Plug-in Processing messing up some VI's
FWIW, dynamic processing is disabled on VI's. So, if you turn it off in the playback engine dialog, you don't see this issue anymore?
:: Bharath
Pro Tools Software Team
Old 11-19-2013, 02:09 PM
Yes it happens with Strike & Superior. I get intermittent sync/ADC issues.
I disable Dynamic Processing and it stops it from happening.
If you change the playback buffer size it helps but it will reappear.
I can't figure out how to get it to start I know a couple of times record arming a track 'sometimes' will make it happen. I have been chasing my tail for 8 weeks or so - on this problem and can't find the cause.
But one thing for certain with disabling Dynamic processing it has not happened once.
Also I am using 96K
Korg VI's not showing up anymore in plug-ins list foxes macOS 4 03-05-2015 09:08 AM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 09:05 AM
50 Spectrasonics VI's, 50 NI VI's and 50 structure all in one pro tools session crizdee Pro Tools TDM Systems (Mac) 11 04-03-2010 09:03 AM
Dynamic Plug-In compatability with 7.3 sass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-17-2007 01:04 PM
Dynamic Plug-In compatability with 7.3 sass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2007 07:42 PM
