ProTools Not Connecting to Artist Mix
I've looked around quite a bit, and I don't see anything that directly applies, or at least solves my issue, so I'll go ahead and ask.
I just added an Artist Mix to my setup. I'm unable to get ProTools to connect to my Artist Mix. I'm using ProTools 12.8.3, EuControl 3.7.0 138, Firmware 1.5.4
So, from the above, it appears that
Now, I go into Protools, and under Peripherals/Ethernet Controllers, I enable EUCON, and EUCON only. When I do this, a popup says Configuring Eucon. Sometimes a few random tracks will become outlined in turquoise, but that's as far as I get. I can't get any other signs that anything is going on between ProTools and the Mix. I've tried trashing all my Euphonix and Avid plists under ~/Library/Preferences. I've uninstalled and reinstalled EuControl a couple of times. I just don't see any improvement. Any suggestions on a next step? Thanks |
Re: ProTools Not Connecting to Artist Mix
What do you have on the Assign Tab in EuControl ?
I got it working. I reinstalled EuConnect for the 4th or 5th time after blowing away the Euphonix and Avid plists in ~/Library/Preferences. A reboot or two later everything started working.
Problems since connecting two artist surfaces | Mirek | Artist Series | 2 | 11-04-2016 10:33 PM |
Artist Mix & Control suddenly not connecting | michael@sounddesign&mix | Artist Series | 1 | 09-15-2016 06:22 AM |
Need help connecting mbox2 to my protools 12 with mac | Dc914 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-10-2016 12:34 PM |
Eucon 3 - Artist Control not connecting to PT | Trazan | Artist Series | 50 | 04-04-2016 03:14 AM |
Problem connecting the Artist series? | Emcha_audio | Artist Series | 0 | 02-14-2014 07:20 AM |
