Old 12-05-2021, 11:51 AM
TheBarnOnMaple TheBarnOnMaple is offline
Default S1 Track Color Keys Issue
I'm wondering if this is a known issue across all S1 units or just my own. Certain color selections in Pro Tools (Dark Red, Dark Green, Dark Pink) seem to not show up at all not the track color keys on the S1 and yellow seems to illuminate more like green. Just looking for any input/suggestions.
Thanks a lot!
Michael
Old 12-06-2021, 02:50 AM
Default Re: S1 Track Color Keys Issue
Same here. Dark red / brown looks like a track with no colour at all. Yellow is green. I guess the LEDs just can't display the whole colour space so you don't see a difference between black, brown and any of the dark colours.
Old 12-06-2021, 08:16 AM
BScout BScout is offline
The keys can display it. They used to look just fine. Yellow was yellow. Dark colours were easy to tell apart. (It's not a hardware limitation)
But then Eucontrol changed its channel strip look (darker strip with only the track label area matching the colour in Pro Tools) and now they don't work well for dark colours. And that yellow is messed up to green (because it is trying to do some weird "dark" yellow.)
Old 12-06-2021, 10:15 AM
EddieJones's Avatar
The S1 hardware colors are completely independent from the Control App. Make sure you have the brightness setting on ALL tablets turned up fully, both in the Control App and the tablet settings. For the Fire tablets you need to turn off adaptive brightness, otherwise it's too dim. This is my iPad on the left and Fire on the right, PT below. To match PT in every way we would have to implement the same color and brightness sliders PT has. We went for the middle ground.
The S1 RGB LED's are hard to get right, to make them better the button plastic would have to be more diffused but that just makes them dimmer. I'll see what we can do to improve them though, but as you turn the brightness up the things change...the yellow becomes worse for example. Ideally these would need a brightness slider too. Someone in a dark studio doing post work would not want them any brighter.
Old 12-07-2021, 09:55 AM
Hm...how do you control the brightness of the S1 colour keys? My surface brightness control sliders are all greyed out as they only work for the Dock and Artist LCD.
Also: What's the colour setting in the S1 colour key hotkey setting for? Somehow I can only get them to display the track colour but not the one I've set for the hotkey.
Old 12-07-2021, 10:09 AM
EddieJones's Avatar
There is no setting currently...I said I'll see what I can do ;-)
Old 12-07-2021, 11:41 AM
Ah right, I misunderstood. Very sorry.
Thanks Eddie!
Old 12-19-2021, 01:10 PM
DJ Hellfire DJ Hellfire is offline
Same here. Even the Green LED's for standard Aux tracks basically look like they are turned off. And I keep my studio fairly dark while working.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 01-23-2022, 12:23 PM
rogerwilco2000 rogerwilco2000 is offline
Found this thread looking to see why my S1 wasn't displaying certain colors on the soft keys. Same here, all the dark colors disappear. My guess it's because the leds are displaying "darker" color as "less bright." If I cup my hand around a key I can barely make out the same shade of, say, red as when a lighter shade is selected. I suppose they're not full RGB?
Old 09-26-2022, 01:40 AM
Chevron Chevron is offline
Well that sucks, it is one feature I was looking forward to on the S1.
I am turning it off as way too distracting as is, what is with that yellow being green.
I have been using mostly dark for years and sso used it, it will be hard to change.
Any update on this?
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
Issue with Track Color in Edit Window robinbjerke macOS 8 05-25-2018 06:22 AM
Avid Artist Soft keys changing color Tim Ripley Artist Series 2 07-01-2016 05:38 AM
Weird track color issue with groups Thumper1040 Pro Tools TDM Systems (Mac) 6 10-07-2011 07:20 AM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
Control+Option+Command/ Color palate track color KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-28-2007 08:54 PM
