Old 07-09-2014, 07:27 AM
rogerwilco2000 rogerwilco2000 is offline
Default Paste to fill into multiple regions
Let's say I have one track with several regions spaced out from each other. Is there a way to select all regions and only paste into the regions, not the total selected space?
Old 07-09-2014, 07:59 AM
joachim's Avatar
joachim joachim is offline
Default Re: Paste to fill into multiple regions
What do you want to paste into the clips ?
Another longer clip, that gets automatically cut and fills just the spaced clips, leaving out the gaps between the spaced clips ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 07-09-2014, 11:29 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Use the replace clip command from the clip menu
Sign up for all things....AWESOME!
Kris
May the music move you
Old 07-16-2014, 09:54 AM
Sorry for the delayed response — thought I was subscribed to updates to the forum but turns out I'm not. :)
Yes! Or something like Paste to Fill, only pastes to fill the regions versus the selected space.
I don't have this command available…is that a HD-only thing?
Old 08-03-2014, 11:00 AM
joachim's Avatar
Can you elaborate on that, since I see no way to replace multiple clips at once ?
Replace clip works for one to-be-replaced selected clip only; and if replacing one after another, all replaced clips will start with the start of the replacement audio.
HD only, see p.796 of the Ref Guide.
Manual workaround would be to place the track 1 with the original clips and the track 2 of the replacement audio clip under each other,
Select 1. original clip, Start-Click the replacement clip to get it to the same start time,
select 1. original clip,
select track 2, "B" ( to divide the replacement clip identical to the original clip),
Select 2. original clip, Start-Click the remaining replacement clip to get it to the same start time,
select 2. original clip,
Select 3. original clip, Start-Click the remaining replacement clip to get it to the same start time,
select 3. original clip,
How to copy and paste regions between sessions? Moog1970 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-14-2008 11:09 PM
Repeat Paste to Fill option in PT7LE? Captain Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2005 08:27 AM
"Repeat Paste To Fill" workaround? Captain Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2005 10:20 PM
how to cut/paste regions without affecting automation? c-post Tips & Tricks 1 11-08-2002 03:13 PM
Repeat paste to fill selection crashes PT's!!? Tim R. Pro Tools TDM Systems (Mac) 7 07-12-2002 10:01 AM
