#111
Re: Play 4 AAX for PT 10 & 11
I had some of the more insidious issues and all is well in the beta that I tested. 4.0.16 will be next, and likely soon. Keep glued to the EWQL site.
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
#112
So they're skipping a few version numbers then? You just know there are people going to make hash of that
#113
Same here.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
#114
Play 4.0.18 is up (though I didn't tested it, I'm still using beta 4.0.16 which solved distortion issues)
http://www.soundsonline.com/Support
#115
#116
#117
Easy. Change the Instrument track insert from Kontakt to Play and open the same patch in Play 4. I'm lucky in that I have both the old original Kontakt-engined version of EWQLSO (and Ra) and the new Play versions of the same libraries so I can do things like that.
#118
1/ I don't know if you replaced plug-in when you first use this release (or if you already opened Play4 normally, and then experienced this kind of crash when replacing Kontakt plugin). Personally, after updating a Virtual Instrument (especially sample-based VIs), I always launch it as standalone* to be sure everything is fine. And then I'm using it as a plugin. Though, I often experienced some crashes when replacing/moving some plugins in certain conditions (with T-RackS, Spectrasonics, etc). I don't know if it is an AAX bug or 3rd party bug. Most of the time, the bug comes from the replaced plugin (so Kontakt in this case). 2/ I wonder if you had any issue with menus and buttons. With PT10.3.6 and Play4.0.18** AAX 32bits version, I was unable to get any windows and menu scrolls except the "main" Player window. If some people experienced this, try to : - Quit PT - Launch Play 4 standalone in 32bit mode (go to [system HDD]/Library/Application Support/East West/ and right-click on "Play.app" clic on "read informations" (cmd+I) and check "open as 32bits mode") - Use the GUI (open all kind of windows and scroll menus) - Quit Play (you can reset it to 64 bits mode if you want) - Launch PT10.3 NB : Normally you just need to do this once and for all : there might be a kind of GUI reinitialization after the update which is not done correctly with the AAX 32bits version. 3/ I noticed a compatibility bug between RTAS and AAX version. When opening a session saved with Play4 AAX versions, Play RTAS version will open empty instances (no instrument loaded)**. For PT10 and PT11, it is not really important because AAX is both 32bits and 64 bits. Except if you want to send a PT session to a PT9 (or less) user (ie : copy saved as .ptf), he will get empty Play instances. I don't know if it was already the case with Play4.0.12. * if this version exists of course. ** this was also the case with 4.0.16
#119
No real problems with the menus or buttons - all work as expected. I thought I had a couple of issues with the menu selection accessing the menu with 'stream from disk' with the menu disappearing with 4.0.18 but that turned out to be a dirty trackball sensor. |
#120
I don't know about trashing databases or preferences in this case, I rarely do it except if I experienced too much troubles. But of course, it often solves many issues too. Quote:
I asked you this because I was still using PT10.3.6 when I installed both Play4.0.16 (beta) and Play4.0.18, and have this buttons/scroll menu issue (that's also why I tested RTAS version to sort this bug out). No pb with PT11 though. I also experienced the same kind of bugs (scroll menus/buttons) with Spaces (beta) and PT10.3.6, but the tip I talked in my previous post doesn't work at 100% with Spaces. So, after reading your answer, I updated to PT10.3.7, and from now on, I didn't experience this issue anymore .
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
Is it possible to play a click without pressing play, and have it in sync.... | ALowe | macOS | 5 | 06-05-2011 04:24 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
When press play the stop key lite and play key blinking | Sam Yin | Tips & Tricks | 6 | 12-05-2009 08:26 PM |
I press play, it doesn't play. hehe - any advice? | awritersparadise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-11-2007 05:24 AM |
