Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 03-21-2013, 08:41 AM
bcwiz's Avatar
bcwiz bcwiz is offline
Default Win7 drivers for 002/003
Ok I'll start.
There has been an ongoing issue with the Digi 002/003 drivers on Win7, specifically the glitch heard when punching in/out (not to mention the delayed reverb tails when transport stops). Documented in this thread; http://duc.avid.com/showthread.php?t=310286 also http://protools.ideascale.com/a/dtd/.../85922-3779and others.
The last we heard from DigiTechSupport was the problem was recognized but no known cause. Is there any possibility that this will ever get fixed? It has been two years since the last Windows driver update for the 002/003 family.
regards
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 03-21-2013, 10:48 AM
sunburst79 sunburst79 is offline
Default Re: Win7 drivers for 002/003
Originally Posted by bcwiz View Post
Ok I'll start.
regards
Despite the Blue Blazes I havent heard a peep on what they are doing with this. That they were able to repo it means its been logged for a fix. How soon? Who knows. Given the fact that the Windows drivers don't needed to be updated nearly as often as Mac drivers I would expect to see this in a future update to 10.3.X OR more likely rolled into a Windows 8 Driver upgrade. The latter would make the most sense. Or PT11 whenever that drops.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-22-2013, 08:20 AM
Paul_S's Avatar
Paul_S Paul_S is offline
Ok I'll start.
regards
Could you try buffer 512 or higher and LLM enabled (as workaround for now)? Let me know if that helps
Old 03-22-2013, 09:50 AM
bcwiz's Avatar
Well believe it or not that actually makes things worse. The glitch is more pronounced using LLM. The problem is improved slightly at higher buffer when not using LLM but it is there regardless of buffer settings.
Anyway, unusable for me.
I have to use a third party interface to overdub with 'cause I'm tired of having to explain to clients that it's not a problem. It would be really really great if this got fixed (soon).
thanks
Brian Campbell
Old 03-22-2013, 10:44 AM
Paul_S's Avatar
Please specify couple things for me:
1. Is the glitch recorded to the audio or it's just a monitoring issue?
2. Sample rate you work with
3. How often does the glitch occur, in all takes?
Old 03-22-2013, 01:12 PM
bcwiz's Avatar
The glitch is not recorded, monitor only, affects playback tracks
I believe some folks reported this being recorded but it's never happened to me
I work at 24/48k
Interesting to note that at 44.1 the problem goes away at buffer settings above 256 regardless of LLM
The glitch occurs every time I punch in/out and regardless of how record is initiated
Brian Campbell
Old 03-22-2013, 03:43 PM
Paul_S's Avatar
Sure, LLM has nothing to do with the problem. On my setup the issue disappears on buffer 512 and above at 48k. I'm pretty sure that this will work on most other setups as well.
Anyway, the bug will be logged and I'll keep you posted on the results
Old 04-26-2013, 07:43 AM
bcwiz's Avatar
Any news/rumors on driver updates?
Brian Campbell
Old 04-27-2013, 09:15 AM
Paul_S's Avatar
Bug logged, work in progress
Old 04-29-2013, 06:45 AM
a100man a100man is offline
In the meantime, I've been using the 8.0.4b drivers with PT9 or 10. This issue doesn't seem to be present in that release, but there might be other problems since it's a really old beta driver. But it's been ok for me. I am looking forward to a new driver that fixes this
Has anyone gotten Win7 X64bit drivers to work on a Mbox2 USB? djgizmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 12-10-2012 05:31 PM
Cannot run drivers for 3 mini in win7 Drew6560 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2011 09:51 PM
Most up to date ASIO drivers for Win7? session_8 Pro Tools 9 1 11-08-2010 10:09 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 07:57 AM
Help-confused drivers for win7 64 in the future? bokos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-13-2009 02:44 PM
