Custom PC Build - Pro Tools issues
I just finished building a PC for my studio:
i7 3770k CPU 16gb DDR3 Ram 2tb HDD 7200rpm 128gb SSD GTX560 GPU Windows 7 Home Premium All drivers/software up to date So far I have installed/uninstalled Pro Tools 3 times and I'm still having a major problem; the playback keeps skipping. A song will play normally for 20-30 sec at a time, then randomly skip a second or 2. I've tried changing every setting I can possibly think of/find online and it doesn't seem to make a difference. Theres no possible way it's a lack of power, as these tracks were recorded on a dual core, 4 year old Best Buy special and played fine. The only possible explanation I have is that maybe my file transfer has corrupted something. I transferred all of my session data using a Toshiba external drive. I have already done this transfer 3 times as well. I just can't seem to figure out what the issue is. Any ideas? Any help would be suuuper greatly appreciated as this down time is losing me money. Thanks in advance! |
What's ur playback settings when it skips?
Re: Custom PC Build - Pro Tools issues
1) What drive are you recording your PTools sessions to? Internal or external? Type of drive? Type of drive connection? Some work well, some do not.
2) Try creating a blank session, then Import Session Data from the questionable session(s). Sometimes this will fix corrupted sessions. 3) Post a Sandra, as explained here: http://duc.avid.com/showthread.php?t=300050
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Chipset
Memory Controller : ASRock Core (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-12800CL10-8GBXL 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-12800CL10-8GBXL 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Samsung SyncMaster (1680x1050, 22.0") Video Adapter : NVIDIA GeForce GTX 560 (7CU 336SP SM5.0 1.7GHz, 512kB L2, 1GB 4.1GHz 256-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 512kB L2, 1GB 4.1GHz 256-bit) Compute Shader Processor : NVIDIA GeForce GTX 560 (336SP 1.7GHz, 512kB L2, 1GB 4.1GHz 256-bit) CUDA GP Processor : NVIDIA GeForce GTX 560 (336SP 7C 1.7GHz, 512kB L2, 1GB 4.1GHz 256-bit) Storage Devices OCZ-VERTEX4 (128GB, SATA600, SSD, 32MB Cache) : 119GB (C:) Seagate ST2000VX000-1CU164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) (Z:) TSSTcorpDVD-ROM SH-118AB (7.6GB, SATA, DVD+-R, CD-R) : 7GB (F:) Logical Storage Devices System Reserved : 100MB (NTFS) Reserved (D:) : 100MB (NTFS) @ Seagate ST2000VX000-1CU164 (2TB, SATA600, 3.5", 7200rpm) SSD (C:) : 119GB (NTFS) @ OCZ-VERTEX4 (128GB, SATA600, SSD, 32MB Cache) HHD (Z:) : 2TB (NTFS) @ Seagate ST2000VX000-1CU164 (2TB, SATA600, 3.5", 7200rpm) Pro Tools (F:) : 7GB (CDFS) @ TSSTcorpDVD-ROM SH-118AB (7.6GB, SATA, DVD+-R, CD-R) Peripherals LPC Hub Controller 1 : ASRock Panther Point LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASRock Panther Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : EVGA GF110 High Definition Audio Controller Serial Port(s) : 1 Disk Controller : ASRock Panther Point 6 port SATA AHCI Controller Disk Controller : ASRock Asmedia 106x SATA Controller USB Controller 1 : ASRock Panther Point USB xHCI Host Controller USB Controller 2 : ASRock Panther Point USB Enhanced Host Controller #2 USB Controller 3 : ASRock Panther Point USB Enhanced Host Controller #1 USB Controller 4 : ASRock ASMedia XHCI Controller FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet) Wireless Adapter : 450Mbps Dual-Band Wireless N Adapter (802.11n (HT), AES-CCMP, 150Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 7.7 |
Anyone have any ideas?
I disabled my wifi connections and that seemed to help a bit, but I'm still getting skipping. I have 2 sessions coming up this week and really need to get this problem sorted out. Thanks guys. |
What are the details of the session?
Sample rate?(96K will use a lot more horsepower than 48K) Bit depth?(I recommend 24 bit, always) buffer setting?(try it at 1024) what interface? I hope you get it sorted. My foray into socket 1155 territory was a disaster
I have almost the exact same system, no issues.
Run this app and see what you get. http://www.thesycon.de/deu/latency_check.shtml Do you have DEP on or off? Check it the Intel 4000 graphics, it works very well with PT. FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr. This might be the issue, see what driver you have for it. Try the MS legacy issue. Also, download Reaper and see if it works. |
My sessions are at 48k/24bit with a buffer size of 512. My interfaces are 2 Steinberg Mr816csx's connected via firewire.
Do I want to turn off the DEP? I have run the latency checker. It hovers around 200 but occasionally spikes or 4000 or worse. The only thing I've tried to disable so far is the network adapter. Maybe I'll have to through and disable everything one at a time to see what is really causing the problem. I've also already switched to the legacy drivers for my firewire card. Thanks for all the help guys! |
Any spikes over 1000 is going to cause issues. Try disabling one thing at a time until the spikes dissipear.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Be sure the Bluetooth is disabled along w the wireless.
Try disabling your on board audio in the bios Try disabling your network adapter in the bios Have you shut off most everything in your startup menu?? Run>msconfig>startup
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Custom pc build | vin7 | Pro Tools HDX & HD Native Systems (Win) | 26 | 06-21-2013 01:20 PM |
Windows 7 Custom Build Compatibility | lbarham | Windows | 8 | 08-18-2012 07:00 PM |
Custom build CPU wont read ANYTHING MIDI | RichieRocks | MIDI | 1 | 03-21-2011 08:38 PM |
New custom build for Pro Tools 9-Help needed | viperbri | Windows | 3 | 03-08-2011 04:15 PM |
Review of my Pro Tools Computer Custom Build | VicSandersMusic | Pro Tools M-Powered (Win) | 2 | 06-21-2009 06:08 AM |
