Re: How does everyone setup Hard drive?
Your 1st and 2nd HDD are SSD, I really want to try System in SSD. Could you give me your feedbacks using SSD? So which HDD do you use for audio recording? |
too same question but how do you like and see benefits in using System and operation PT soft on SSD? I know it's super quiet. (I have Air). Also is your mirrored system HDD with RAID system? Thanks A2C |
For your eSATA, I think you use eSATA PCI card, which card do you use? I have one from Lacie. |
No body still using Thunderbolt yet?
I got my eSATA PCIe card from OWC. I forget the brand...it was $47.00. Might be "Newertech."
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
#16
#17
Drive 1 - Macintosh HD Drive 2 - Audio Drive Drive 3 - Video Drive Drive 4 - System CLONE Quote:
No.
#18
Interesting thread!
Here is my current test system. This system curves other system implementation. Drive 1 - Macintosh HD 1TB Drive 2a - Media scratch (2TB Partitioned in two) 2b - Library, Samples Drive (2TB Partitioned in two) Drive 3a - System CLONE (Superduper) (2TB Partitioned in two) 3b - Library, SFX Drive (2TB Partitioned in two) Drive 4 - Audio on-line working 1TB Optical Bay 1 DVD Optical Bay 2 Blu-Ray Xternal Raid 5 for Video Xternal Singles for BU - BU clone Archiving Recently added 4 bay independent racks for Raw drive usage thus cleaning up the many single drives and their power supplies. DiskCatalogMaker for scanning all Drive content database e.g. search database, it tells me the location and drive. Get the drive from the Drive locker find the files. T.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#19
Long story short, if you partition 50/50 then the first part is stored on about 33% range in the outer edge of the disk. That in effect cuts max seek times to 33%, provided that the storage partition is not being used when you record. So, if a drive manufacturer advertises 12ms latency, this trick brings it down to about 4ms which is great. Effectively doubles the track count that the drive is able to sustain without hiccups. But this is only true if the inner part (storage partition) is not used at all while you track or playback.
#20
My work drive is 10k rpm and I never have to worry about it.
Hard drive setup | abre | Storage Subsystems | 2 | 05-15-2013 06:21 AM |
Is this Hard Drive setup ok for PT? | Georgerob | General Discussion | 7 | 10-25-2012 03:01 AM |
Hard Drive Setup | rfrance | Pro Tools M-Powered (Win) | 14 | 06-03-2010 08:33 AM |
Which Hard Drive setup is better? | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-07-2007 06:24 AM |
Hard Drive Setup | where02190 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-15-2002 12:41 AM |
