Cracks and Pops when changing session sample rate
Hi!, I usually work with 44.100 Hz - 16 Bit sessions. A couple of days ago I record in 44.100 Hz - 24 Bit, and here comes my trouble. When I´m working in 16 bit sessions and then open the 24 bit session, my M-audio Interface goes out of sync and there is a loud crackling and popping in every channel, the only way to solve this issue it´s to shut-down my system and open the 24 bit session from scratch.
Does anybody had this problem?, Any suggestion?, I´ve tried to update the interface driver but it´s up to date. thanks!
MacBook Pro 13" 2.3 GHz Intel i5 4GB DDR3 320GB Snow Leopard 10.6.7 M-Audio Profire 2626, Behringer ADA8000 M-Audio BX5-A Deluxe Monitors Pro-Tools MP 9 |
Re: Cracks and Pops when changing session sample rate
You're not actually changing the sample rate (still 44.1), only the bit depth (16 to 24). This shouldn't be a problem. Is something changed that you're not seeing?
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
thanks!
I see that you have an Behringer somewhere in your chain!Might be the problem!
I use two Profire 2626 and never had that problem, normally i change sessions from 88 to 44 and the only thing that happens is PT to crash , but i open again and all is Ok after ... |
thanks for your suggestion!, I´ll let you know If it works out.
Sample Rate Not Changing With Session | Siegfried Meier | Pro Tools TDM Systems (Mac) | 1 | 04-28-2010 08:23 AM |
Changing Session Sample Rate ? | 25ghosts | Pro Tools TDM Systems (Mac) | 3 | 06-09-2007 05:42 PM |
Changing LE session from 48 to 44.1 sample rate | ansanity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-12-2006 11:11 PM |
Changing the sample rate of an existing session | Torgo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2004 08:52 PM |
Changing Sample Rate On An Exisiting PT Session??? | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-01-2004 11:00 AM |
