Anyone using a plasma display as 2nd monitor
Anyone using a plasma display as 2nd monitor ?
I have a 22" cinema display on a dual monitor supported G4. Does anyone see problems putting a 32" plasma on the vga output of the G4's card ? thanks, -russell |
Re: Anyone using a plasma display as 2nd monitor
I queried Digi on this subject and the answer ws I needed to get a different video card as the Nvid card tied down the PCI bus too much to allow using 2 22" Cinema displays. I have not gone ahead and done it as I would have ot get and expansion bayas the G4 Dual 800 is full and there is no room for the Video card as I am running and HD3 system. Sorry I cant recall the name of the Vidcard they told me ot get for Dual monitors.
If you do get around to doing it i would be interested in hearing how well it works.
Stuarta |
I have run my 42'' plasma with an additional VGA monitor on a dual (twin View) card on my G4, and no problems, except that plugins redraw were a little slower, but that was also the case if I was running two regular VGA screens...
A slightly different question... Has anyone successfully run TWO 22inch(or 23inch) apple cinema displays with the new Nvidia Titainium card? I mean all digitally.
Thanx. |
Ray,
Have you had any problems with burn-out on the Plasma? when I looked into these as a possible large-screen solution, I was told that they are not designed for static images. Evidently, you must manually refresh the screen every once in a while, or they can be permanently damaged. Is this bunk? Also, are you using a 4:3 or 16:9 aspect ratio? How does the PT image translate? |
looks like I'll be answering my own question next week.
Ray,
I'm bumping this, hoping you will see it and respond. As plasma prices are dropping noticeably, they are becoming a viable choice. I am very confused about the aspect-ratio thing, and concerned about the burn-out thing. thanks. |
I'm intersted as well...
what abou the interference/emi thing? do they emit radiation... more or less than a CRT? What about the energy consumption thing? 360 watts is alot!!
------- xxx |
Bump.
Ray, ya' out there? |
I've been running 2 cinemas digitally off the titanium card for about 2 months. Works great.
Jamie |
Plasma display burnin? | uno1234 | Post - Surround - Video | 3 | 04-02-2007 07:03 PM |
More info about Cinema display and Sony Plasma 50" | ampnerd | Pro Tools TDM Systems (Mac) | 0 | 04-12-2006 02:02 PM |
Plasma Display and a Canopus | soundguydave | Pro Tools TDM Systems (Mac) | 7 | 03-01-2006 01:42 PM |
problems with gateway plasma display | timmygrimm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-19-2003 09:16 PM |
Using a plasma monitor w/PT | Donnie | Pro Tools TDM Systems (Mac) | 5 | 12-03-2001 01:15 PM |
