Old 04-21-2008, 07:52 PM
Anthony Orsino Anthony  Orsino is offline
Default No audio coming out of the Monitors?!?!
Everything seems to be connected correctly, nothing is muted in my mixes. I'm using a MBox Mini with a iMac Duo Core running OS X 10.4.11. Suggestions anyone???
Old 04-21-2008, 09:52 PM
Default Re: No audio coming out of the Monitors?!?!
bump
Old 04-21-2008, 10:33 PM
sky88dd sky88dd is offline
Is the mix knob on the mini turned to the middle?
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 04-22-2008, 01:22 AM
Phil Ogden Phil Ogden is offline
Amp or powered monitors turned on? If so do other audio applications playback OK?
Old 04-22-2008, 08:21 AM
flommer flommer is offline
Are your monitors connected to the Mbox? That is the only way to monitor ProTools...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
no sound coming out through monitors BtotheZ26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-23-2012 07:22 PM
Playback is coming from Mac rather then Monitors gobertub Pro Tools 9 3 10-07-2011 12:02 PM
Noisey high freq buzz coming thru monitors from M-Audio 410 SixChurchStreet Pro Tools M-Powered (Win) 9 12-21-2008 12:33 PM
No sound coming from monitors shortyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2007 06:12 PM
static sound coming from monitors madoneman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-26-2006 03:37 PM
