when do I bounce multi mono versus interleaved????
Most only use interleaved bounces, but when would multi mono be best?
My Official Website My Official Music Forum Myspace Page Soundclick My Youtube Channel |
Re: when do I bounce multi mono versus interleaved
When you're going to import the mix back into PT. E.g., you mix a tune, bounce it down to split mono at 24-bit 96 KHZ, import those into a new session for mastering.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
see that is exactly opposite of what others have said. Does anyone know the convention? Help!
cary,
"Dual Mono" is PT's native format. If you are importing back into a PT session leave it at that. "Stereo interleaved" would be the format most other wave editing, CD burning applications understand. hope this helps, a
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Lemix is right. And it's not really a matter of convention so much as of convenience. Why have PT go through the work of interlacing the two channels and then splitting them apart again? It not only takes more time, it takes twice the disc space.
ok thanks! I never knew that. I just had two replies on another forum saying that if you are importing for a submix or if mastering in PT it needs to be interleaved.... If PT works only in multimono, then that makes sense to me. I do have one question, when opening the bounce menu why does it automatically go to stereo interleaved by default?
Also, if I am bringing my mixed 24 bit tracks for mastering, should they also be in multimono?
should submix-bounces to be imported also be at multimono ?
bump
Stereo Interleaved vs Multi Mono | studiojimi | Pro Tools TDM Systems (Mac) | 17 | 12-08-2009 11:20 PM |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Post - Surround - Video | 0 | 06-08-2007 09:06 AM |
multi-mono versus mulit-channel plugin | pietro79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-21-2007 02:33 PM |
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-13-2002 11:08 AM |
Multi Mono vs Multi Channel Plugins...Just curious... | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-18-2002 09:46 PM |
