Auto Save?
Is there a way to disable PT from saving every single take?
Re: Auto Save?
Put it in Destructive record mode and it will overwrite each take.
Bazzle |
Re: Auto Save?
if you mean saving sessions, there is an autosave feature in the Setups - preferences menu. You can deselect it. If you mean regions, you want them. You can Clear unused regions.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Re: Auto Save?
I highly recommend you not use Destructive record mode! The only situation to use it is if you want to replace the complete recording - a situation which usually only occurs when doing transfers from another recorder. You have the potential to get yourself into major trouble with Destructive record mode.
As Cliffy says, learn to delete unused regions. Rail
Re: Auto Save?
i have been deleting unused regions... but when i open the session i always get an annoying message box saying there are 50 or so files missing.. how do i avoid that?
Re: Auto Save?
If you save the session after deleting the regions you shouldn't receive that message.. something else is causing it.
Rail
Re: Auto Save?
are u using pro tools to delete the unused regions or
are you going into the audio file and deleting them urself?
www.klarityrecordingstudios.com |
Re: Auto Save?
Bazzle |
Re: Auto Save?
Because there's no Undo in Destructive record mode. I only use it when doing transfers - any other use should require the user be 100% sure they know the limitations.
Rail
Re: Auto Save?
Thanks for the response.
Bazzle |
Auto save bug | sw rec | Pro Tools 10 | 4 | 12-04-2013 10:59 AM |
(-50) ERROR on Save / Auto Save | oldrake | macOS | 1 | 10-14-2013 03:30 PM |
Auto Save ? | ian Bourgal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-01-2009 08:59 PM |
auto save | jmallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-16-2005 06:26 PM |
Auto Save: what say you? | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-30-2001 06:36 AM |
