Old 03-20-2013, 12:37 PM
Bender Bender is offline
Default PT10 Saffire 56 and Rosetta 800
I had used my Rosetta 800 with PT 10 and my 003 for years
Now I have the Saffire 56 and the setup windows are different because you have to use the Focusrite mix Control at the same time.
Anybody using this setup
The Focusrite manual does not show that setup
Thanks
Old 03-20-2013, 01:36 PM
Meads Meads is offline
Default Re: PT10 Saffire 56 and Rosetta 800
You only have to setup the mix control once. After that you can forget about it.
I've got the same setup at home, and it works very well.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 03-20-2013, 01:47 PM
Thanks
When I used the 003 with the Rosetta 800 I only used the 8 adat channels
Can I use the 8 adat channels from the 800 and the analogue from the LS56 at the same time
Thanks
Old 03-20-2013, 01:49 PM
Still don't quite get, what you're trying to achieve, but I'm on two beers, so it might be me.
If you're on OSX you could create an aggregate device consisting of the Rosetta and the LS56, or else you feed the LS56 with the 8 Rosetta ADATs via Lightpipe.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 03-20-2013, 01:52 PM
I get it now
I did not know I could select them seperate
Thanks Again
Old 03-20-2013, 02:14 PM
nst7 nst7 is offline
You can use the Rosetta via Adat exactly the same way with the 56 as on the 003.
Old 03-20-2013, 02:36 PM
003 setup
sample rate 44.1
wc I/O sync (all lights should be off)
lock wide/narrow light both on
source to digital outs, set to analog
output res 24 bit
source to analog out, set to adat
Light pipe (optical) out from 003 to rosetta in. word clock off the rosetta.
choose adat in optical format window, clock source, set to optical
I mirrored rhe setup for my LS56 but I don't see the above options in Hardware setup
Old 03-21-2013, 10:51 AM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi Bender,
This should be very easy to set up via Saffire MixControl and we would be glad to help you.
The options you are seeking for Sample Rate and Sync Source are in Saffire MixControl.
If you want to use the clock from the Rosetta you can set the Liquid Saffire to follow it using ADAT or Word Clock as you desire in the Sync Source box in Saffire Mix Control.
If you want to use the clock from the Liquid Saffire you would set it to Internal and select ADAT or Word Clock on the Rosetta.
If you would like assistance setting up your system please dont hesitate to contact our Technical Support directly and we would be glad to help you:
http://us.focusrite.com/contact-support
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 03-22-2013, 12:40 PM
Thanks Kathrine
PT10 and Saffire Pro 40 I/O Issues Electrigician Third Party Interfaces 13 04-17-2014 12:27 PM
PT10 + Saffire 56 liquid pre's help sflight Pro Tools 10 10 10-02-2012 11:11 AM
Focusrite Saffire 56 + PT10 sflight Windows 7 03-28-2012 08:52 AM
Saffire pro 40 with PT10 fireberd Windows 13 01-07-2012 11:27 AM
Focusrite Saffire 24 DSP with PT10 chumphries1290 macOS 0 12-12-2011 02:20 PM
