Old 03-17-2019, 11:10 PM
ErikGuldager ErikGuldager is offline
Default MC AAF export changed in 2018.10?
Did MC AAF export change in 2018.10?
I read that since the last few releases it is required to have MC/PT at the same version level because of AAF inconsistencies.
We have had a few issues lately where PT just wouldn't link up som files in the AAF properly.
I read about it on gearslutz, and as we are in the process of updating the last few MCs to 2018.12 we may be starting to see this issue creep up.
I just want to know more.
Links to any info appreciated.
Old 03-18-2019, 01:40 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: MC AAF export changed in 2018.10?
A known bug MCCET-2825 causes some AAF exports with embedded media from recent versions of MC did not to import correctly into PT's 12.7.1 and earlier.
Chatter in the MC forums around the time of the last MC update suggested that a fix for this, though not in the last release (MC 2018.12.1), was being worked on and could be expected soon.
Andrew
Old 03-19-2019, 12:48 PM
Todays update I have not tested this yet but the readme with MC 2018.2, released this morning, indicates the problem is resolved.
Bug Number: MCCET-2825. An AAF embedded export from Media Composer did not import properly into Pro Tools v12.7.1 and earlier.
If you experience this problem, enable the “ProTools 10/12 compatibility” option in the Export As AAF dialog. The exported AAF will be compatible with earlier versions of Pro Tools.
Note This does not apply to AAF's exported with linked media
Andrew
HTML code is On
PT 2018 Export Clips Bug?? indeloon85 Pro Tools 2018 0 09-16-2018 07:29 AM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Pro Tools 2018.1 crashing during audio import/export Robert Torres Pro Tools 2018 5 02-06-2018 01:46 AM
Can Dither in Export Prefs be changed to PowR Dither Mr. Anxiety Tips & Tricks 5 10-31-2009 10:28 PM
