Old 04-19-2018, 11:41 AM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
Default Conforming a multitrack to an edited timeline
From time to time when remixing live music for broadcast I find it more productive to conform the unmixed multitrack to the editor's timeline and finesse each edit across all the tracks before mixing. It makes hiding edits easier by having some tracks move to the new sync before the edit, and some after. It also means you can attack the mix as a whole instead of having to break down each song and reassemble it later.
The problem is I've never come up with a satisfactory way to conform several hundred edits across 64 tracks. It's aggravating having to do each edit by hand, but I'm not conversant enough with reconform software to know if it can be automated.
My present workflow is below, it works as long as Edit Keyboard Focus is on. I’m certain it can be done faster, chime in if you have ideas.
1. Reveal Original Time Stamp in clips
2. Spot entire performance multitrack to original timecode in timeline (that brilliant idea was from Scott Moore at United Recording)
3. Group aaf and multitrack tracks separately
4. Select entire aaf clip you want to conform
5. Separate Timeline and Edit Selection (Shift + /)
6. Press / on numeric keypad 3x to highlight Edit Length field, copy (C).
7. Press / again to highlight Edit Start field, enter original Start number from aaf
8. Press / twice to move to Edit Length, paste (V).
9. Center Edit Start (left arrow key) and move Edit Selection up or down so cursor is in multitrack area
10. Copy (C)
11. Press Play and Stop to get back to Timeline selection
12. Press Edit Selection to Timeline Selection (0 on keyboard)
13. Copy (V).
It’s clunky, but it works and doesn’t require any mousing. Ideas?
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
Old 04-19-2018, 09:22 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: Conforming a multitrack to an edited timeline
Hi Peter,
If the live music record is a set of WAVs that can simply be spotted in the timeline you should be able to to the PT HD/Ultimate Field Recorder function 'Expand Channels To New Tracks > By Timecode Only'. I would have thought selecting this on one of your AAF tracks would find all WAVs in the session that have matching TCs for each AAF clip and place them on new tracks.
Alternatively, if you have made edits to the live music recordings before it was sent to editorial, or the above doesn't work, you can use EdiLoad to automate this. EdiLoad can import the edit info from one or more AAF tracks (or from audio EDLs) and you can then apply these edits to your music tracks using the EdiLoad re-conform function.
I created a video in the following blog post that details how to re-version mixes, not exactly what you're looking to do, but the second half of the process which uses the EdiLoad re-conform function is what you could use to automate this process:
Reversioning Pro Tools mixes with Ediload
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 04-23-2018, 01:50 PM
I actually tried the Field Recorder Workflow, but Pro Tools was unable to find any matches despite having the correct pathways entered. I suspect the fact that the aaf I got did not have the media embedded and was just the EDL metadata may have something to do with it. Pro Tools has no problem finding matches for actual files on the timeline, but it seems to be unable to do so for a "phantom" clip that just has timecode data.
If anyone has a way to confirm or deny this I would be interested.
Peter
www.remotewest.com
@RemoteWest
HTML code is On
Recording multitrack with master track V.S. Recording multitrack then record master T Rockman413 Pro Tools 12 0 03-08-2016 08:46 PM
Grr.. Link Timeline Edit Track Edit Timeline Selection confusion deepfrequencies macOS 3 02-06-2014 02:40 PM
Does PT 8 allow all playlists to be edited? rtcstudio Pro Tools TDM Systems (Mac) 14 03-22-2009 11:50 AM
Pop between edited regions John Peeples 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2008 09:10 AM
Mix playlist changes when edited 001 The Doubter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-25-2001 11:51 PM
