Re: File Export Bug in 2020.3
Thanks. Yes, I'm only using AAF files to share work in progress with editor and director. Won't get into the detail, but it's less tedious for me than sharing timestamped WAV files when the project is being constantly recut as I'm exporting cues from Logic Pro X into PT and then want to send a bunch of ideas. My final deliverables as always will be on a PT session with sound team.
I tried moving file start point to frame-based boundary and unfortunately the issue still remains. Thanks for the suggestions. |
Yes i did check 'Enforce Avid Compatibility'
My regions were not cut on the grid and then exportetd When I import it back into session then the regions get extended (to the next frames) . Everything is in sync. Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
I was speculating as to what would happen if a clip boundary was between frames and there were no handles. Would the clip be trimmed to the next frame edge within the clip boundaries? Would the clip be moved on a subframe level to the nearest frame edge? If the latter, that would definitely be a bug in my book. Considering that nothing came back incorrect in your tests, I think we must assume its a bug or an issue with the OPs system or particular session.
Scott Gatteño |
I wouldn't assume anything. As I said in an earlier post, I'm using two different computers to test this and it's not confined to one session, but any session I open. But thanks for the suggestions. Last edited by midi sordino; 05-04-2020 at 02:54 PM. |
Scott Gatteño |
Thanks. Yeah, the sessions I’m checking this on are pretty empty. No plugins and only a movie file with audio imported from the movie. Then some audio tracks with stereo clips of music cues imported from Logic Pro X. I recently updated to 2020.3 and haven’t changed anything from the default settings since download. But perhaps there’s a setting somewhere that is causing this issue. Will have another look tomorrow. Cheers, M.
Hello all!
I had a .Wav file that I exported (not as AAF just .wav) to an editor to do some re-cuts on a completed show. He resupplied me my mix as an Embedded AAF so that I could conform his edits. The timestamp of the file start was off by 1 frame. All the timestamps at each edit point were off by 1 frame. I imported this into 2019.12, timestamps were fine. I believe that this is an IMPORT issue not export. |
If I don't check this box, the re-imported timestamps on the wav files using AAF import are correct. But I want to enforce media composer compatibility, so it looks like this may be an issue when exporting an AAF file from PT using this option (which might as well be called 'Enforce Pro Tools Incompatibility') |
F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Thanks for your reply. I exported using the full frame grid (something I thought I'd already tried) and that finally sorted it. I can now send files that will match timecode stamps when imported into Media Composer & Pro Tools. Appreciate the feedback. Is it possible to also export volume automation into Media Composer or is it only clip gain?
Cheers, N. Last edited by midi sordino; 05-05-2020 at 06:36 AM. |
Bounce to Quicktime Movie File Crashes Pro Tools in 2020.3 | JRV | Pro Tools 2020 | 6 | 04-19-2020 07:41 AM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
mp3 export doesn't show correct file size til another export done | obidon | Pro Tools TDM Systems (Mac) | 0 | 12-09-2010 01:13 PM |
How do you export an omf file???? | NEIGHTD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-01-2006 11:04 AM |
