Re: PIA SSL strips & ducking
I'm never on GS, but I'll take a peek. Thanks again.
I believe it is only with the plugin gui open but can't verify that. What does seem to mitigate the problem is to change focus from the plugin gui to something else.
Thanks Jack, I appreciate it. I've send you an email.
Re-installing didn't seem to do the trick. Oddly, when I load the SSL E as a VST in BlueCat Patchwork the vst presets are there. Could be a Hackintosh glitch I suppose... T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
By the way, I can't reproduce the plug-in 'stealing focus', either with the old E & G or the new E.
Even with the plug-in window open the return key works normal at my end. T
This might well be a true Mac issue. When I reported it to PA's tech support I told them I was running on OSX 10.10.5 and it happened in PT, DP, Patchwork. It's not that it steals focus but that it reacts to the 'return' key being pressed. To explain: say I set some buttons on the PA strips. Leave the plugin gui open and I go to manually enter a value for say a send or output in PT and hit the 'return' key to have PT accept the value the controls I changed in the strip will change to the state they were in previously. If I change focus to another plugin or such the 'return' key won't affect the strip controls. |
#16
Thanks a bunch Jack, works a treat.
For the record, this is on 10.10.5 too. PT 12.8.1 T
#17
Try this: New session. Create an aux track and put the SSL strip of choice on an insert. Make a change from the default setting like selecting the G compressor if you have the E strip open or vice versa. Change the track name and hit enter to accept the change. Does the change you made go back to the default setting? Leave the plugin gui open. Should happen whichever control you change (even the knobs/pots). |
#18
To be absolutely thorough I tried the exact test scenario you described above. Same result; the plug-in settings are not affected. I've been using the old Console E for a year now and I have never encountered the 'glitch' you described. I assume you've already tried the ol' Thrashing Of Prefs thing? T
#19
If you're doing this on your Hack can you try it on your real Mac? |
#20
T
Ducking | NativeLuv17 | Tips & Tricks | 3 | 10-27-2008 04:47 PM |
Ducking within the console | timcorder | VENUE Live Sound Systems | 1 | 06-21-2008 02:35 AM |
Ducking | Eless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-24-2005 12:05 PM |
Ducking | strizzack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-07-2005 05:01 AM |
Ducking? | neil_mcdermott | Tips & Tricks | 9 | 07-11-2003 11:53 AM |
