signal generator automation and distortion
I have tried to automate a slow sweep sine wave from the signal generator plug-in (to help calibrate monitors/PA systems), but the plug-in produces varying degrees of distortion ( which it doesn't do when you adjust the Hz within the plug-in window)
I'm assuming that it has a problem with non-integer values it is receiving from the automation. As the distortion continues after I have stopped the transport, I think I have ruled out the possibility that it is the transition from one value to the next during the sweep that is causing the problem. So- Has anyone else experienced this? Has anyone worked out a way around the problem? |
Re: signal generator automation and distortion
I have always used the tones off of the TMH Test Disks
http://www.hollywoodedge.com/TMH-Dig...eries-P54.aspx SG is not a very good piece of code
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Signal Generator Automation Bug | Sonopolis | Pro Tools 10 | 4 | 07-08-2013 12:41 PM |
Use of a signal generator | reverieman | Pro Tools TDM Systems (Win) | 1 | 10-25-2006 06:59 AM |
Bug in 7.2 Signal Generator | Craig F | Pro Tools TDM Systems (Mac) | 1 | 10-12-2006 03:17 PM |
Signal Generator in 6.1 | Clash310 | Pro Tools TDM Systems (Mac) | 2 | 08-29-2003 04:54 AM |
Signal Generator | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-09-2002 05:56 AM |
