Old 05-09-2002, 07:54 AM
simonchase simonchase is offline
Default "save session copy in" audio file name shortening
Hi there.
I have all my audio dotted over 25 drives.
When i want to get all the audio for one particular session in one place i "save session copy in" and tick the "copy audio files box".
When i do this, the new audio files have lost the last four characters of thier file names. (in my case ".aif")
This means other sessions that were linked to the same audio files cannot link to the new audio files until i manually type ".aif" into the file name. Then it works fine.
Is there a way of getting protools to stop truncating my filenames?
Thanks for listening.
PT Ultimate 2020.11 - MacOS 10.15.6 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet
Old 05-09-2002, 02:51 PM
Paul Greyson Paul Greyson is offline
Default Re: "save session copy in" audio file name shortening
If you save the session w/ Mac/PC compatibility mode it'll keep the .aif extensions.
Paul Greyson
Digidesign Engineering
Old 05-10-2002, 05:39 AM
Thanks - that worked fine.
The problem that now emerges is that I want to save as SD2 files but I can't. Again, not a big problem - I'll just save as AIFF. However my default file type for the other sessions is SD2. Thus when I open these sessions and search for the audiofiles it finds them ONE AT A TIME (even though they're all in the same folder) AND... for EVERY audio file, it asks me if i want to use the "wrong" file type - well yes i do but i don't want to tell the machine this 500 times. (Actually in my case it's more like 25 times but it could be 500 or even 2000!) Is there any way around this?
Thanks again.
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 01:25 PM
"Save Copy In" producing session without audio holden Pro Tools TDM Systems (Mac) 12 12-16-2008 06:44 AM
Backing up/"Save Session Copy as" over a Network biigbrew Pro Tools TDM Systems (Mac) 2 11-18-2008 02:48 PM
disk error 37 on "Save session copy in" simonchase Pro Tools TDM Systems (Mac) 0 07-03-2002 04:37 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 01:33 AM
