Can someone tell me the difference
can someone tell me the difference between Pro Tools 8 LE and Pro Tools HD?
iMac 27inch 2.8 GHz Intel Quadcore i7 8GB 1067 MHz DDR3 2TB internal Memory 2Glyph external hard drives 003 Rack Pro Tools LE 8 Logic 8 & 9 |
Re: Can someone tell me the difference
http://www.digidesign.com/index.cfm?...24&langid=100&
and http://www.digidesign.com/index.cfm?...28&langid=100&
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
HD uses PCI style plugin cards that connect to select digi interfaces for I/O but also provide a certain amount of DSP power for plug processing (TDM) without taxing the host system. The specific plugins for TDM generally cost a bit more than native RTAS versions and they only run on HD systems. There are also some track limitation differences and other little odds and ends. I'd say when your ready for PTHD you'll know the differences. |
Way too many to list out.. Do you have the PT Reference guide pdf? If so, browse through that and you'll see all kinds of things that are "HD only".. Some big difs would be: ADC, higher track/bus limit, low latency recording via the HD hardware, DSP hardware.. Some more subtle difs are the automation options, group options, sync options, and about 1000 other things that you wouldn't know were different until you found it in the manual..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
I really hope that within a few months these differences will dissapear slowly. Not all, but many I hope.
Yes, I am optimistic.
my blog:Tamas Dragon |
What's the difference? | williamsoncj | General Discussion | 3 | 08-16-2010 01:45 AM |
What's the Difference? | cpnraisnuts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-28-2005 07:44 PM |
what's the difference between 5.3.1. and 6.4 | king of the south | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-12-2005 02:09 AM |
difference between -10 and +4 | stickytapenrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-22-2003 08:22 PM |
L2 - big difference! | JACEK GAWLOWSKI | Pro Tools TDM Systems (Mac) | 1 | 01-22-2001 11:53 PM |
