Old 10-11-2002, 12:37 AM
Default 002 transport buttons sticky
Anyone else have a problem with their 002 transport buttons getting stuck down - my biggest culprit is the STOP button.. which pops up with a big CLICK when I press the PLAY button next to it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-11-2002, 02:28 AM
JROB6716 JROB6716 is offline
Default Re: 002 transport buttons sticky
Well. i wouldn't know if mine is going to do that because I didn't get it yet. Had it on order over a month now.
I did however play with it at AES LA. They had several units there. Didn't notice that problem with the Transport. But I did notice that the PAN knobs were pieces of **** and didn't rotate smoothly at all. Hopefully it's because they were DeMO models or something...
Take it back , get a new one.,,,,
J
Old 10-11-2002, 03:40 AM
Phil O'Keefe Phil O'Keefe is offline
The pan knobs are just push on knobs... they were probably pressed on too far onto the pot's shaft and are rubbing against the unit's main faceplate. Pull up on them slowly with gentle pressure and they'll come off. Put 'em back on, but don't press down so hard that they scrape the top of the main faceplate.
Phil O'Keefe
Old 10-11-2002, 02:18 PM
That's good to hear Phil, Thanks for the heads up. By the way, where did you get yours?
I am still waiting. I was told around the 15th or 20th
Thanks
J
Old 10-12-2002, 07:44 AM
I got mine from Sweetwater, and had it here by Sept. 27th. So far so good!
Phil O'Keefe
Old 10-12-2002, 10:15 AM
Axehell Axehell is offline
Yep, my transport buttons are a bit sticky. They seem to be getting better with use though. I think that the rough texture on the side of the button eventually will be worn smooth and the problem will dissipate.
MC Transport Buttons...LAG! sartis Artist Series 0 03-16-2012 04:57 PM
Transport Buttons CHRIS AIKEN ProControl, Control|24, Command|8 0 12-10-2011 02:21 PM
New Transport buttons Johnny Hulst ProControl, Control|24, Command|8 1 04-23-2008 05:25 PM
Help in Replacing Transport Buttons (is it possible?) Mastersonics ProControl, Control|24, Command|8 3 02-08-2003 09:28 PM
No buttons on transport window!!! dooni Digidesign Hardware & Software 2 05-29-2001 09:23 PM
