Old 11-08-2011, 11:01 PM
Keith Matthews Keith Matthews is offline
Default Strike 1.5 on PT 10 with OSX Lion DAE Error -7054
Hi Everyone,
I just purchased the Strike Plugin 1.5 upgrade for $99 in order to continue using strike now that I have upgraded to Protools 10 as the 1.0 version of strike was not compatible. (I purchased PT10 about 2 weeks ago)
However, after installation I get a DAE error every time I try to use the plugin. PT10 starts up OK, the error occurs as soon as I try and insert strike into an instrument track.
This did not happen with the old 1.0.3 version. (it only had graphics and data source issues.
The Error is
"The plugin could not be made active because a DAE error was encountered. DAE error -7054 was encountered."
Running protools 10 on MAC OSX Lion 10.7.2
I have tried removing all and re-installing All plugins and PT 10, same issue. My ilok shows that the license is good and has been installed.
Strike works fine under Windows 7 in my BOOTCAMP partition. Of course I use MAC OSX for my normal studio work so I must get it working under that OS.
Any help would be greatly appreciated as it is clearly a problem for Avid support. But I am not going to spend another $40 paying for a AVC support code when the fault is almost certainly the Software which I have only just purchased.
Regards.......Geo
oooOOOooo
Old 12-03-2011, 01:52 PM
edomenig edomenig is offline
Default Re: Strike 1.5 on PT 10 with OSX Lion DAE Error -7054
Having same issue. Looking for a solution
Old 12-03-2011, 04:25 PM
The "Set Strike Content Location" application should be used when Strike cannot find its data files (e.g. if data files have been moved to another drive).
Latest version working with PT10
http://avid.custkb.com/avid/app/self...p?DocId=355459
PT10 in /Applications/Avid/Avid Virtual Instruments/Strike
I suppose for PT09 in /Applications/Digidesign /Strike
Old 12-04-2011, 04:52 PM
marrap's Avatar
marrap marrap is offline
After installing the update of Strike you should reinstall the Pro Tools 10 Upgrade.
PT 10 will update Strike or other AIR instruments to work with the latest PT
version.
wolfgang funk
marrakech prod
www.marrakechprod.com
www.linkedin.com/in/marrakechprod
https://pro-labs.imdb.com/name/nm3047395
Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX.
Yet another DAE error - 7054... Simon Andersson macOS 2 12-29-2013 05:25 PM
DAE error -7054 for Strike sricabla Virtual Instruments 1 07-29-2013 11:54 AM
dae error 7054 C V MUZIK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2013 01:52 PM
Dae error 7054 Safjuan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-22-2008 09:36 AM
DAE Error #7054 lowoctave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2006 11:09 PM
