Old 10-22-2011, 09:21 PM
Hovak Hovak is offline
Default Pro Tools quit unexpected
Hi there,
After installing Pro Tools 10, it gives an error message.
" Pro Tools quit unexpectedly "
Why is this happening ?
Thanks,
Old 10-23-2011, 05:56 AM
jemd jemd is offline
Default Re: Pro Tools quit unexpected
Check what plugin is displayed just before it crashes and move that plugin from your plugin folder to the not used plugins folder.
Old 10-23-2011, 12:52 PM
It crashes 3-4 seconds after it scans everything ... I don't think it's a plugin issue.
Old 10-23-2011, 04:09 PM
Guitarman002 Guitarman002 is offline
I have had the same error message numerous times when using the Strike plug in. I have to start over each time after the crash.
Old 10-23-2011, 04:48 PM
how did you fix the problem ?
I am not using Strike ...
Old 10-24-2011, 11:47 AM
bump
Old 10-24-2011, 01:01 PM
Ant B Ant B is offline
This is apparently cross platform. I had this happen a couple times on windows last night - 1 time without even the message, just a system freeze. Happned using the channel strip while recording
Old 10-24-2011, 01:29 PM
How did you fix it ?
Old 10-24-2011, 01:45 PM
I stopped recording with the channel strip active lol
I didn't have the time or patience to find a permanent solution last night, was in the middle of a session. I'm going to do a laundry list of tweaks and throw out some old outdated plugs that should have been gone awhile back and see if that does anything.
Old 10-24-2011, 02:47 PM
I understand your situation, but mine is not even running.
It gives me an error message after it scans everything.
Pro Tools quit unexpected when opening... Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-30-2011 04:12 AM
The application Pro Tools LE 7.1.1 quit unexpected neilshah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-25-2007 11:34 PM
10.3.9 LE6 unexpected quit creativebond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-31-2005 01:02 AM
Unexpected Quit with Pro Tools 6.7! Need HELP js54 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-29-2004 04:24 PM
Unexpected quit beholder74 Pro Tools TDM Systems (Mac) 1 11-26-2004 12:30 AM
