Old 07-15-2010, 12:47 PM
donrey donrey is offline
Default Yamaha NS-10 Problem
I've been experiencing this issue with my NS-10's.... The right speaker sometimes sounds dimmed (as if that channel had been turned down significanlty). I'm able to get it to come back to normal levels by turning the volume up and playing any kick drum with a lot of 'pop' to it (ie. around 90 to 100 hz). Once I play this sound the speaker sounds normal and i have no issues with it. However, the issue returns once the equipment hasn't been used for a while. I also notice that once in a while a humming sound will come from the tweeter. It's not always there and i haven't been able to figure out a pattern.
I'm thinking it could be the tweeter or the cones going bad but I thought i'd post the question to see if anyone else has had this issue...
Troubleshooting I've done:
1) checked cables
2) checked channel on Hafler (tried speaker on the other channel and issue persisted)
3) switched plug hafler was hooked up to.
Current Set Up:
-Hafler TA1600
-Presonus Central Station (with Remote unit)
-Monster cable 3500 power unit
-Mac Pro
-HD1
-192 (i/o)
-liquid channel (connected to the 192 via AES)
-no other monitoring
Old 07-15-2010, 02:58 PM
Third Eye Studios Third Eye Studios is offline
Default Re: Yamaha NS-10 Problem
To me it sounds like a cold solder, bad cable or a ribbon cable that needs cleaning/re-seating. Just bypass one component at a time until you can narrow it down. Divide and conquer!!
Third Eye Studios.org
Old 07-15-2010, 04:55 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
NS10's are notorious for blowing tweeters, if you haven't already you should definitely consider fusing the tweeters. One feedback loop is all it takes.
Sounds like your problem is definitely in the speaker itself. You could try swapping tweeters between the two, then woofers. Also while you're in there pull out the insulation and look at the crossover board, there might be something obivious there like a bad connection or some burn marks
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 07-15-2010, 05:40 PM
Kenny Gioia Kenny Gioia is offline
Not sure about the tweeter (I never blew one) but the woofer sounds like it's going.
Just enjoy it for a few more weeks. Maybe.
Hope I'm wrong.
But if pushing on the cone brings it back, it's going.
Solo a bass track and pan it back and forth. If you hear distortion on that side, go buy a new one.
Old 07-21-2010, 01:16 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
We have 3 pairs of NS-10Ms and beat the snot out of em... never an issue.
Fusing the tweaters is a very popular old safety trick. Worth doing.
The big red flag in my eyes is the Hafler TA1600
That amp SUX!!!!
I love Haflers, don't get me wrong, but you need the P series :) 'Transnovas'
I have a P1500D and a P3000D. Solid. Workhorses.
In 5 years, we came across 3 bad TA's.... . Crummy little turds.
Try switching your left and right, see if it follows the amp channel.
If not, speaker, if so, amp.
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 02-03-2011, 06:44 PM
Varela Varela is offline
Choose an expensive Dynaudio's setup and leave your Yamaha's on the Buy & Sell topics!
Old 02-04-2011, 10:29 AM
Top Jimmy's Avatar
I myself also suspect the Hafler. I have a Pro1200 from before the trans-nova design and had nearly this exact behavior once. $70 at the shop and my fave bench tech fixed it.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Yamaha 01v96v2 problem behan Pro Tools 11 5 01-24-2014 09:04 AM
help! sound problem between 11r and yamaha head pierre.pan Eleven Rack 5 03-30-2013 08:58 PM
Yamaha NS-10 Problem donrey Pro Tools TDM Systems (Mac) 3 07-15-2010 02:41 PM
Yamaha P-80 Problem Strad MIDI 0 01-14-2002 02:16 PM
Yamaha 03D level problem andre tchmil Tips & Tricks 6 04-16-2001 06:54 AM
