Old 12-07-2009, 02:28 PM
sbag sbag is offline
Question You learn sumthing new everyday
I was watching some u tubes video and discovered the pre section in the send window. This definitely help me with my mixes. Forgive me but i should
I should have known but I didn't.
My question is can someone explain the difference between the pre and post fader in the send window. Forgive my ignorance.
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
Old 12-07-2009, 02:34 PM
Ben Jenssen's Avatar
Default Re: You learn sumthing new everyday
If you engage the "pre" switch on a send, the send is "pre fader", in other words the send sends a signal even if the channel fader is all the way down.
Typical application: independent headphone mix.
Old 12-09-2009, 08:47 AM
systemexclusive systemexclusive is offline
Another example of using "pre fader" send: Build reverberation tail louder than original signal.
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8
mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop
r3, microQ, Albino3, impOSCar, Structure
m1active 520 & sub gw s750, deq230, cx2310
Reintalling PT everyday!!!!!!!!!!!!!!!!!! Empireofthesun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 10-21-2008 06:22 PM
Are any pro studios using PCs for everyday tracking? brianjanthony Pro Tools TDM Systems (Win) 41 01-29-2008 01:29 PM
Why everyday I must to change preferences? wasabi Pro Tools TDM Systems (Mac) 1 04-16-2007 11:56 AM
Tools you cannot be without everyday. madcow Pro Tools TDM Systems (Mac) 16 10-11-2006 08:35 AM
Help! Lexiverb plugin required direct3ddraw or sumthing??? hokuspocus Pro Tools TDM Systems (Mac) 4 04-19-2002 03:53 AM
