Closed Thread
  #171
Old 09-19-2007, 05:36 AM
Robert S. Robert S. is offline
Default Re: Audio Record or Playback Volume Error Info
Just a quick thank you to the Admin and everyone in this thread. I had this same issue after installing 10.4.10 up from 10.3.x. I was stuck for a day or two until I read and then installed the 6.9.2 upgrade and repaired permissions. I am back up and running and couldn't be happier.
Thanks guys! I came for the fix but I think I'll hang out a bit and see what other great tips you guys have for PT LE.
  #172
Old 09-26-2007, 12:47 PM
Univac Univac is offline
I have done everything everyone has suggested in this thread but still unable to get the drives to switch to R or P in the workspace. This is a really odd phenomena especially since Abelton, Logic Pro and Reason work just fine with the same content from the same drives. Has digi come up with a solution yet?
  #173
Old 10-04-2007, 07:48 AM
sagiglobal sagiglobal is offline
Default My PT 7.3 freezes when I try to play a recording
Hi
Can some one help me
  #174
Old 10-04-2007, 09:23 AM
DigiTechSupt's Avatar
I purchased a Maxtor 320 gig external drive and I am getting the same DAE 6085 error.
am using PT 6.4 om panther 10.3.9
Did you ever figure out how to solve that issue?
shredder48
You'll need to supply more info - check out the 'Help Us Help You' link below my signature...
Avid Audio Tech Support
Support FAQ
  #175
Old 10-04-2007, 09:25 AM
Default Re: My PT 7.3 freezes when I try to play a recording
Hi
Same goes for you...Help us help you.
Support FAQ
  #176
Old 10-04-2007, 09:32 AM
And once more - we need more info to be able to assist you....Help us help you
Support FAQ
  #177
Old 10-06-2007, 11:55 AM
dendee dendee is offline
re: Cant Change External Drive to Audio Record Volume.....Digi do you mean reformat the internal drive or the external one that we cant change to "audio record drive" ?
Also having this prob....when closing a session i get told:
Could not complete your request because Neo Assertion in "/Volumes/Developement/vb_cliff/AlturaPorts/SDKs/Neo61/Libraries/Macintosh/Environments/Alone/../../../../Source/CNeol0Block.cpp", line 164.
The only way to quit protools is to "force quit" every time. I am however able to open the session again and find that it saved the prior session correctly.
Please help.
Thanks,
Denny
MacBook Pro 2.33 Intel Core Duo 2GB
OS X 10.4.10
MBox 2 Mini (also own 002)
Protools 7.3.1
G-Tech Drive 500 Gig (this drive cannot be changed to audio record volume)
Boot Camp 1.3
-win xp pro
Closed Thread
workspace - audio record volume juicytunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-17-2010 04:33 PM
"Session must be on an Audio record volume" - Workspace info jojo101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-19-2007 06:07 PM
"Session must be on an Audio Record volume" - Workspace info DigiTechSupt Pro Tools M-Powered (Mac) 20 03-11-2007 07:23 PM
Audio Record or Playback Volume Error Info jarno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2006 06:22 PM
need help :workspace audio record volume nicolas paris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2004 06:51 PM
