#71
Re: Best SYstems and Components for Win HD/TDM
Are those HD PCI cards you are using? or PCI-e cards?
Asrock Fatal1ty X299 - i9 7960X- 128GB DDR4 - 3x m2 samsung evo 2TB pciex4 SSD - Geforce 3070 ti - Win11 x64 - PT HDX - HD Omni - HD I/O |
#72
Hi There,
are those the PCI vesrions of the HD cards???? (or PCI-e)
#73
Hello,
If they were PCI-e though (I can't speak for others but I believe they are not)... I think PCI-e on XP is unsupported at this time. Len |
#74
Re: Best Systems and Components for Win HD/TDM
Has anyone tried any of this with a lowly 3800-939/x2? I have a 3Gb ASUS A8N-DL SLI/GeForce 6200 Video and couldn't get it to work with my HD1/7.0 system - boot failures and pretty blue screens. Is this possible? Ideas?
TIA, Therm |
#75
Can I ask if anyone knows whether the Quadzilla system Shane built is capable of running an HD4 setup?
It looks like I'm being forced into a quick system build due to issues with our current rig, and this looks like the best high-power option at the moment .... unless there's information on working Xeon (Woodcrest) or Core Duo systems I've missed. Many thanks for any feedback or advice. Jules |
#76
Any update on PCIe? Who has a working PCIe system? Please post your parts.
Myself, I need to build an HD 1 system. Here's what I'm thinking of getting. http://www.cty.ca/system_customize.asp?205
Back to basics: Strat, DRRI, and pedals gallore. |
#77
Hi!
No update on HD PCIe for XP yet. I would imagine word should surface at or by AES, since it is such a big show. Just a guess... Since PT seems to favour certain chipsets, I would seriously consider waiting until Digi announces the intial compatible boards/systems to see which chipsets are qualified...unless you have the cash and time to start experimenting. In that case, I would opt for an Mbox (used, for less $$$) with the first test board until XP is ready for HD PCIe. Then you can sell the Mbox, or keep it as a prtable solution.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
#78
Hi Guys,
I'm currently setting up a win hd 2 accel system on a supermicro H8DCI mobo. So far everything went ok, but there seems to be a problem with the Accel card... When a plug in loads to the Accel card, the output is accompanied by lots of white noise. (both cards are in PCI-X slots, the Core is in the first PCI-X 133 slot, the Accel card in the second PCI-X 133 slot) When running digitest, I get the following error: TDMII Flex cable test (bus B DSP I Failed: expected 11EE11h actual 11EC11h) (just to be sure) I ordered a new Flexcable...hope that solves the problem Anyone seen (heard) this problem before?
#79
Hello,
I would also see if the Accel card passes Digitest without the flex cable installed/connected (which it should if the card is okay). You've probably done this but make sure the cable is connected properly. Port B on the core card to port A on the Accel card. I've had a couple flex cables fail in the past so??? (they are also extremely delicate). Good luck! len |
#80
Re: Best Systems: ANRF vs ANRF-RS
So, I just ordered a 2877ANRF-RS from Newegg, and noticed that there are ANRF boards & ANRF-RS boards. What's the difference? Is this a problem for Quadzillas?
Although the specs from Antares & Newegg seem the same, the Newegg one specifies -RS, and the 2877ANRF-RS is listed a little differently on the TYAN page. Whazzup? TIA, therm |
Are these pc components ok? | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 08-13-2010 11:20 AM |
need help with HD components | FMR_Crisis | Pro Tools TDM Systems (Mac) | 9 | 04-17-2010 05:07 PM |
What components lie in the most POWERFUL native PTLE Systems? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-28-2008 07:18 AM |
Will these PC components do the job | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-06-2007 08:22 PM |
components | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-19-2001 09:32 AM |
