7.4 RTAS Usage meter higher than normal! Any thought\'s? HELP
Hello I've been running 7.3 flawlessly for a while now. Just went to 7.4 last night and opened up existing sessions and the RTAS usage meter(this is new isn't it? before was just cpu usage?) is at half and in 7.3 the cpu usage was under a quarter. Had about 14 plug ins open.
So now that there are split meter's one for elastic time and RTAS are they reading differently? what's up? Or does 7.4 just take alot more processing to operate? if so i may go back as i'd rather have asccess to more RTAS then elastic audio. HP a1440n Intel 820 Viiv dual core processor, 2.8ghz, i945p chipset 3gb ram dedicated 250gb sata HD
Mac Pro 1,1, Intel Xeon 2.66 Quad Core, 6 GB Ram OSX 10.6.8 Pro Tools HD 9 HD 2 Accel System, 192io, Macbook Pro 5,5, Intel Core 2 Duo 2.53, 4 GB Ram OSX 10.7.2 Presonus StudioLive 16, Cakewalk UA-25 ex USB Studio: www.sonicpit.com |
Re: 7.4 RTAS Usage meter higher than normal! Any thought\'s? HELP
I upgraded to the Digi003 this year [7.3] For the first month Pro tools software had many issues and thanks to those CS releases [cs5] which seemed to have fixed issues. Still I do get some random errors of access violations etc. As I was thinking to upgrade to the 7.4, I saw that I will be charged $49 for the upgrade. This is quite ridiculous. I guess 7.3 had many errors I say this because DigiDesign has never released 3CSs at quick succession. My Boxes are P-Dual Cores with 4g ram + 200 acres of space, running XP [Home Edition] Everything is fine except for the random access violation error, my observation it that this happens when I connect USB devices like card reader or external hdds. Reading above comment, I guess I should not upgrade, I better off living with random access violations errors. Thanks.
Independent Music, where raw passion and untamed creativity meet and thrive, a refreshing departure from the mainstream. https://dfyus.bandcamp.com https://www.youtube.com/@Srikanthd |
7.4 is a bit of a CPU hog and EA cannot be turned off since its more or less "Embedded" in PT.
Sriks.. There is a known issue with PT and Card readers. If the device is USB unplug it or you can disable each of the card readers drives in Device Manager. Delete all of the Digidesign Databases and reboot and reluanch Pro Tools. This may help.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
thanks - Sunburst79
That's what I do, but it does get tedious during fast production cycle. I use the Motif ES + sampler, I transfer wav files to motif sampler using a build in multi card reader drive,after each mix down I was forced to reboot the box to transfer files. but thank god, last month, I got one more PC that came with a SD card reader slot, which is now mapped via network to protools box, I transfer files via network, then delete the network mapping. With such known issues - Digi charges for an upgrade? why?
Higher DSP usage in PT9? | suicune | Pro Tools TDM Systems (Mac) | 20 | 09-07-2012 12:19 PM |
How much memory usage does your PT take up on normal launch ? | hwill2008 | Pro Tools 9 | 2 | 04-27-2011 07:11 PM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
RAM usage is over 1.3GB on a simple session...normal? | spinecraft | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-08-2008 02:18 AM |
Anyone use SiS chipset? Normal CPU usage? | illfi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2002 08:22 AM |
