#21
Wrong - but whatever have a good cubase experience - don't let the door hit you in the arse on the way out !!!
#22
Re: Pro Tools Wont Even Load PATHETIC.
How am I wrong? all other options are disabled :s
You sir, are a very patronizing person, see how far that gets you in life. I'll leave it at that. I'm not here to bicker like children I just want to be able to do my university work at home, I didn't come here for sarcy comments about how I should've built my PC etc. |
#23
Pt has always been picky about systems. This is nothing new and why people come here to help spec builds and avid gives us stickies on the threads for the builds. I put a lot of information above, probably the most your going to get. Until your willing to go through these procedures instead of assuming and shortcuttimg things, there is not much we can do.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#24
So you are transferring these files onto your os drive and trying to run them from there??? That very well could be bandwidth issues. Have you tried recording a 96k track?? Honestly I could not see no reason to work this high anyway and would drop them down to 48k (exactly half) on your host. Do you have a 7200 rpm external usb2 drive to try them on?? Do you have an antivirus running? Have you turned off most things in the startup options?? Have you defragged your C: drive?? Have you shut off unnecessary services?? Again go through my last list, you skipped a couple very important things. Never assume your ram is fine. Did you set the proper speed and latency setting in the bios?? You have a ways to go before you can blame the software I think....
#25
What a ridiculous fix, didn't find that anywhere in the optimization list. AVID should be appalled. Thank you for trying to help though :) |
#26
Hence why Adobe never fixes any of its program cracks, they want people to be used to it so they become the norm, then when you actually some software for business use you go straight to them. |
#27
#28
#29
There are a whole bunch of folks out there sucessfully using Pro Tools with many different interfaces and computers.
It is not an easy piece of software to get working in it's current state, but I suspect near real-time programs are always going to require some extra care in system configuration. Since it may be the focusrite driver has anyone contacted focusrite? |
#30
Naw that's not it Dave - he said he changed the windows sample rate to 96k that means he probably had the playback engine setup all along as the asio -(and probably doesn't know how to change it back) but I digress its not worth it to bicker with a kid in school - let him get his professor to straighten it out - for god sakes
I always find it amusing when they come along and say - I seriously considering (insert ur favorite other daw here) if avid doesn't get their stuff together !!!! Whatever
Pro Tools SE Wont Load. | Jay_Enna | Pro Tools SE and Essential (Win) | 0 | 05-04-2011 02:39 PM |
pro tools wont load | matt.brack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-25-2010 07:39 PM |
Help! Pro Tools wont load | Istarri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-07-2009 02:00 PM |
Pro tools 7.3.1 or 7.4 wont load | tah money | Pro Tools M-Powered (Win) | 3 | 08-14-2008 05:20 PM |
Pro Tools wont load | premonitionofmisery | Pro Tools M-Powered (Win) | 13 | 02-08-2007 12:03 PM |
