Old 11-21-2009, 02:57 PM
D3lta D3lta is offline
Default Automation adding distortion?
I'm running Pro Tools 8.0 (original, un updated) and I'm doing automation on a mix and I'm hearing what seems to be distortion where the automation is happening. Has any one else experienced this? I'm trying to figure out if it's a product of the software, or the computer not keeping up.
Old 11-21-2009, 05:03 PM
rqstudio rqstudio is offline
Default Re: Automation adding distortion?
Not quite enough info, does it sound like zipper noise or does it only happen when you turn the volume up on something? Without knowing more I can only suggest you bring all the faders down, (group all) this way you won't have to change all the automation moves. You can highlight all the channels, put them in volume edit mode and drag them all down 5db's or so. Select a point after the end of the song, make sure they all go down beginning to end not just another breakpoint.)
Old 11-21-2009, 06:05 PM
The Weed's Avatar
The Weed The Weed is online now
Do you have a Master Fader? Is it at unity? If so, follow the advice above. If not, put up a Master Fader at unity. Is it clipping? If so, follow the advice above.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-22-2009, 02:53 PM
The master fader is well below unity, and nothing is clipping. The sound is like a digital garbling..or worbling. I have my drums, rhytm, main gtr, bass and vocals all in their respective groups. It's when the automation occurs is makes the worbling noise on the vocals. I've done other automation passes with gtr and it doesn't seem to do it.
Old 11-22-2009, 05:15 PM
scottedog scottedog is offline
Long shot maybe but is it an Elastic Audio type warble?
Scott.
ScottedogStudios on ReverbNation
Old 11-22-2009, 06:03 PM
Elastic Audio isn't even enabled It's really bizarre.
Old 11-22-2009, 06:15 PM
AlexLakis AlexLakis is offline
Does changing the buffer size, disk buffer, etc. in the Playback Engine preferences have any effect on it?
Old 11-22-2009, 06:21 PM
I have not tried that, but I will once I get back to the studio.
Old 09-27-2022, 10:18 PM
natedawg3973 natedawg3973 is offline
13 years later --- and this is happening to me in PT12 on a Studio MAX ... did you ever figure out the problem?
Old 09-27-2022, 10:47 PM
Pro Tools 12 on a Studio Max???, however you managed to get that to work, is likely to explain this and many other problems you will have.
The OP has not been here for like a decade... and it's extremely unlikely there is any relation between whatever you are seeing and what they saw.
Adding Automation to plug-in DonaldM Tips & Tricks 8 02-15-2010 11:21 AM
Hard Drive adding distortion priechm Pro Tools M-Powered (Win) 2 04-17-2006 12:27 PM
Mbox adding noise/distortion - where to repair? tcline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-16-2006 07:39 PM
Adding some distortion/fuzz to a bass line nero120 Tips & Tricks 8 04-21-2005 11:25 PM
digirack delay plugin adding distortion? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-17-2002 06:05 PM
